My sharp atomic clock spc 900 won't show and outside temp. Have reset it many times and put new batteries in it.
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: ss 5000 sound spa
Atomic clocks are tricky. The clock defaults to PST.
Turn OFF the atomic time feature (The little radar icon will disappear) Make sure that you have clicked the DST/TZONE button on the back of the clock to YOUR timezone (a P,M,C,or E icon will appear on the front screen.) Then turn the atomic feature ON and hopefully - all is well!
Posted on Nov 02, 2008
SOURCE: instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: 3M Precision Digital Atomic Wall
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
SOURCE: I have a skyscan atomic
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
You can order replacement transmitters from http://skyscan.info/content/
They only cost $11 and that includes shipping and handling.
Posted on Feb 07, 2009
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
How do i get the outside temp. to work
If you have a outside sensor add betteries.Wait for it to connect to the base. You may have to "reboot" ,remove batteries from base and outside temp sensor and replace both, Patiently WAIT I have a similar device and once a year I replace the batteries It takes a while for the devices to re-connect and set , the atomic clock as well. That said, How far is the Temp Sensor from the base unit? I set my outside sensor near the base to connect and move it on th outside porch (30' away) out of the direct sun and rain. I not sure if this is necessary but that the way I reset them.
Nov 04, 2012 | Sharp Spc315 Atomic Dual Alarm Clock
No visible outside temp. on SkyScan
Read some other posts on the net and they said to put in new batteries.........bingo!  That did it!
Aug 23, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Instructions for setting Sharp Atomic clock
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Sharp Atomic Clock spc 373 won't display correct time/zone
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
Sep 23, 2008 | Zapf Chou Chou 716212
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
146 people viewed this question
 Grubhead
Grubhead
