Definitive ProSub 80 hums - Audio Players & Recorders
  • AaronH Nov 29, 2012
    Sorry. I posted this too quickly. When plugged in, the Pro80 emits a electronic, almost modem-like sound, as it comes to life. Then it begins to to emit a increasingly loud hum that build and levels of after 20 seconds or so. Volume controls have no effect. This happens whether the audio cable is plugged in, or not. Just needs to be powered on.
Prosub atmosair rebuild manual I have an older prosub that I got a rebuild kit for but need instructions to take it apart and rebuild it.
You need to consult with a factory technician. Your life depends on these devices. I am certified in USD Survivair and no one can set those after a rebuild kit without special tools and measuring devices.
Jul 26, 2015 | Scuba Diving & Snorkeling
ProSub 600 tripping off during playback of low bass and turns on after a while but works perfectly if volume is turned down. what could be the problem?
  • The DSW ProSub is a nice amplified sub. The reason it is shutting down is the amp is being worked to hard and it's going into thermal mode and after you turn down the volume and it cools down it's coming back on. To much of this and you will have a nice sub and no amp to run it.
  1. One thing to do is keep the sub/amp in a well ventilated are and put a fan on it if you can to help move the heat away from the unit.
  2. The amp is rated at 250 watts so if you push it to hard it's gonna keep shutting down. So turn it down a little so it runs longer and smoother or add another sub to the set up if you need it louder (like we all like). One sub can only do so much.
  3. Also make sure if the receiver your using has a base setting or an EQ that you keep them levels set a little lower. Most receivers and home theaters already have an amp in them and you don't want to run to much of that into another amp. It's over kill. Find that happy medium.
  • If you have any questions or comments please feel free to ask.
  • Thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Definitive ProSub 800 Subwoofer Speaker
Pro sub just shut down no red signal light dead what could be possible problem?
start at the basics, check home circut breaker box, ensure it is still plugged in, check the fuse subwoofer itself. unplug and disassemble, to ensure no moisture or a fried bug is the sorce of the problem, ensure the leads to the subwoofer havent popped off or become crossed, etc etc. hope this helps
Aug 09, 2010 | Definitive ProSub 800 Subwoofer Speaker
Definitive Pro-Sub 1000 subwoofer replacement fuse.
Fit a 3 or 2.5 anything lower, if you can get away with it, but nothing higher.
However the chances are that it blew due to an overload, often caused by a shorted semi-conductor acting like it was a piece of wire. So even fitting a smaller one and it blowing again doesn't mean it's due to the rating.
Jun 25, 2010 | Definitive ProSub 1000 Subwoofer Speaker
I have a Sony Receiver STR DA2400ES with a Definitive Technology ProSub 800 Subwoofer. Lately, I noticed that the subwoofer isn't working. I did a system test and it didn't work. The power light on the...
Prove it's alive by feeding it the signal from any other source, like Left or Right Tape Out. Use FM as the source to keep things simple. Then we can move forward with analyzing the correct failing unit.
Dec 28, 2009 | Audio Players & Recorders
Difinitive prosub 600 keeps turning its self off??? I have connected the sub every which way, low level RCA to sub out, using the prosub 600 as a bus for the front monitors, even both together. I have...
"Somthing seems to be wrong with the automatic on/off???" That's my guess too. Your sub requires a certain signal level to turn on, probably because of a sub-sonic filter. I just changed to another sub that did not have that "feature". Problem solved.
Jul 19, 2017 | Definitive SubAmp 600 Amplifier
Kenmore 80 series wash machine humming
you have a clogged pump
the pump is hooked directly to the motor if thats cogged the motor cannot move producing a humming sound
Oct 07, 2009 | Washing Machines
Subwoofer with screech and static
This sounds like the output stage of the subwoofer amp has failed -- needs service...
Charlie
Aug 22, 2009 | Definitive ProSub 1000 Subwoofer Speaker
64 people viewed this question
 Grubhead
Grubhead
