Question about Fantech DBF4XL Dryer Booster Kit w FX4XL Fan
Fantech does not shut off
Fantech DBF4XL does not shut off when dryer cycle is completed
  • Antonio DiFruscia Nov 26, 2014
    It will remain on for awhile when dryer cycle is done but it does shut off a little while after which i found out is normal
2 Suggested Answers
  • 63 Answers
SOURCE: fantech exhaust fan won't shut off.
Faulty switch (replace it) or Loose switch (wrap the body with electric tape)
Posted on Sep 12, 2009
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
I have a Gas Whirlpool dryer model GGQ9800PW3. The dryer stops before the cycle is complete. It can be restarted, but again it will work for a while then shut off. I changed the temp setting from med
Oh oh sorry to say this but sounds like the motor windings are going bad? does it shut off then about 30 to 60 minutes later u can start agin? a bad cycling thermostat or thermistor could be culprit but I doubt that in ur case.
Sep 27, 2014 | Dryers
We have a Maytag Electric dryer that is not heating up totally. Removed the vent tube and seemed to help but I check the Ohm's on the thermometer and was working. Tsted the col for ohms and at the RX1...
Hi, If your resistance is 2-3 Ohms, then your element is on it's way out . It needs to be replaced. The resistance should be in the range of 7-20 Ohms on a 240 Volt dryer heating element with the multimeter set at RX1. Good work finding that.
There are some additional reasons a dryer will not dry, have no heat, or cause the element to burn out prematurely.
1 If the exhaust vent run distance is too long. i.e. more that 15 feet the heating element life will be shortened Why? Because in a long vent run the vapor from the most clothes condenses on the sides of the vent hose and lint sticks to it. This lint accumulates and reduces the internal diameter of the hose. This increases air friction and the element runs at a higher temperature, etc. etc.
Solution: Clean the vent system out, or replace with a shorter system, if possible. There is an accessory fan available that can be installed that allow you to have a very long exhaust vent run. See Link
http://www.hvacquick.com/products/residential/Dryer-boosting/dryer-booster-fans/fantech-dryer-boosters?utm_source=google&utm_medium=cpc&utm_term=dryerboost&utm_campaign=fantech
2 Exhaust vent hose folded or squeezed almost or completely shut at back of dryer. This ocures when the machine is too close to the wall pinching the hose. No air carrying the moisture leave the dryer.
It can get hot and after the cycle is done. The clothes are still wet. Solution: Pull out dryer and unfold hose.
NOTE:
Don't use a dryer without a vent hose attached. The dryer will pull the hot air with lint in it back into the machine. Over a period of time this lint can accumulate in the machine and cause a "lint fire" Lint fires inside a dryer sometimes turn into house fires.
Hope this helps,
Happy New Year
Mark
Jan 01, 2011 | Maytag Neptune MDE7500AY Electric Dryer
DLE0332W--dryer continually runs like its in wrinkle free mode. Will not complete regular dry cycle.
You may have an issue with the control board and it will not shut down once the cycle has been completed. You will need a qualified LG technician to diagnose the problem.
Good luck
Sep 29, 2010 | LG DLE3777 Electric Dryer
Fantech exhaust fan won't shut off.
Sep 12, 2009 | Fantech Dryers
Kenmore Gas Dryer completely shutting off mid-cycle
sounds like you have a overload switch kicking out or its a thermofuse, or timer something is telling your machine its too hot or a thermofuse or some heat sensor....
Jun 08, 2009 | Kenmore Dryers
Kenmore 68702 electric dryer heat doesnt shut off
If the dryer completes the cycle bit does not shut off, then you have to replace the timer control assembly.
If instead the dryer hangs at the middle of the cycle and does not advance, check the thermostate.
If the dryer does not heath and does not advance, then check the heating element, the thermostat and the fan.
Mar 06, 2009 | Kenmore Dryers
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Fantech DBF4XL Dryer Booster Kit w FX4XL Fan Logo
144 people viewed this question
Top Fantech Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Fantech Washing Machine Expert? Answer questions, earn points and help others
