Question about White Sewing 2037 Mechanical Sewing Machine
Bobbin stuck on bobbin winder spindle
I have rewound my bobbin but I cant get it off the spindle now. The spindle moves left and right, but the bobbin wont move up or down.
  • hrnancy_3
    hrnancy_3 Dec 02, 2012
    I could not pull the bobbin off so finally unwound all the thread from the bobbin and was able to remove the empty bobbin. I wound second bobbin and had no problems. When I wound a third bobbin, couldnt get the bobbin off. It seems that something is snagging a thread and preventing the bobbin from releasing.
  • I suggest checking the bobbins that are get stuck on the spindle and see if they are warped or damaged some way or it could be the notch on the spindle is catching some how.
  • White Sewing Master
  • 7,365 Answers
You might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
Posted on Nov 29, 2012
  • Theresa Savage
    Theresa Savage Oct 30, 2014
    I am having the same exact problem. Something is obviously very wrong with the bobbin and/or the spindle!
  • Theresa Savage
    I managed to get the bobbin off the spindle by unwinding all the thread from the bobbin. It may have been wound too tight. Now I'm going to try to rewind the bobbin but going much slower than I did the first time. I hope this will let the thread wind with less pressure so the bobbin doesn't get stuck on the spindle again.
Brother 1100, was sewing , now it is froze, cant turn the wheel far either way, cleaned, wants to go but is stuck, I cant see any thread in bobbin plate but I think that is where issue is advise
You could check the bobbin winder shaft. If this is engaged the machine appears to have frozen while turned on. Move the bobbin winder shaft left, then right while checking the foot controller and you will soon know if this is the problem.
Nov 08, 2016 | Brother Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Can I fix a broken bobbin winder on my Janome sewing machine by myself?
If your bobbin winder is malfunctioning and you are unable to resolve the issue, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or even online (Amazon).
Oct 30, 2015 | Janome Sewing Machines
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
Singer 362 bobbin
It appears from the manual (see pages 9-10, which are on 11-12 of the pdf version) that it is necessary to disengage the hand wheel (loosen the center knob) with the bobbin winding lever all the way to the left, before putting the bobbin on the winder spindle. Put the bobbin on the spindle, then set the winding lever to the right position to engage the spindle drive. Do not tighten the hand wheel knob until after the bobbin is wound and the lever is moved back the left to permit bobbin removal.
If you are following these directions exactly, or you can't get the hand wheel knob loose, you have a mechanical problem to solve. You may need a stronger hand to loosen the knob, or something in the bobbin winder is bent, out of adjustment, or jammed with foreign material. If you are mechanically inclined, you may want to remove the top cover of the machine for inspection.
Dec 02, 2013 | Sewing Machines
Elna 6200 stuck in bobbin mode but sticking
Is the bobbin winder spindle on top of machine pushed over to the right in winding position? Move it back to left to change back to sewing mode.
Nov 30, 2013 | Elna Sewing Machines
Singer curvy
Three possible causes: 1.Bobbin not push fully down the bobbin winder spindle
2.Need to push bobbin winder spindle to the left before you can wind the bobbin
3.The bobbin winder spindle rubber ring has worn out. This will need a local technician to fix it.
Aug 16, 2013 | Sewing Machines
Brother VX1435, needle won't move
some machines when the bobbin winder is engaged will not sew, do you
have to disengage the center wheel in the handwheel to wind a bobbin?
or do you have to just move the bobbin winder spindle to the right to
wind the bobbin?
do you have a manual for the machine?
Sep 06, 2012 | Brother VX1435 Mechanical Sewing Machine
Cant fill bobbin the wheel does not go round on 131 newhome sewing machine
check the bobbin winder spindle... can you slide it to the right or left? If so do that.
Aug 05, 2012 | Janome Sewing Machines
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
White Sewing 2037 Mechanical Sewing Machine Logo
1,212 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
