Question about Pioneer SD-532HD5 53" Rear Projection Television
Pioneer projection tv SD-582HD5
After 10 or 15 minutes you hear a poping sound,the tv powers down.The power light on the front goes from green to red.At the rear of the tv,on the right side looking from the rear,there is a power board that is setting vertical that has a power down LED on. After 20 minutes you can turn the tv back on,and it start over again. Please help if you can.
    Problem Solver:
  • 15 Answers
I had the same problem, try running the TV on Mute, if it is a bad solder joint the sound can vibrate the solder point and trip the relay, if the TV doesn't trip off with the sound on mute then it is probably the big power transformer's solder connection needs resoldered. sound vibration from those big pioneer speakers may loosen the solder joint over a period of time because the transformer is heavier and bulky and vibrates a lot.
Posted on Sep 13, 2009
    Problem Solver:
  • 7 Answers
Mine would do this, or a variation where it would pop, flicker, the brightness would go all wonky and stay bad for several minutes+. Just recently it went pop, and went dead. When turned off at the hard switch and turned back on, it would make the relays click but would not make that high pitched transformer tweet sound that it always made on startup, then turn back off.
I pulled the power board out and looked at all the solder connections on the back side based on other posts here at fixya. Several were ugly and needed touching up, but one was cracked, slightly burnt, and obivously broken. That connection was on the big transformer in the middle of the board, seemed to be the culprit.I desoldered it, cleaned it up and resoldered it. Cleaned up about ten other connections that generally looked like they would fail soon, put it all back together, and it works again!
If you try this yourself, be VERY VERY careful! Just because there's no big tube inside, doesn't mean you can't kill yourself with electricity! Unplug it first, keep the plug visible, keep the kids away, use one hand wherever possible, and be careful soldering, you might have one end of a charged capacitor that may not like what you're doing!
Posted on May 30, 2009
I had the same problem 2 years ago IResolded all connections on the power board and that fixed that prolem
Posted on Feb 26, 2009
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
SD-532HD5 TV shuts off when watching
Its is a cold solder joint on the board. The board is the one located at the bottom right of the tv when looking at the rear. Mine did the same thing. After refreshing mose of the large solder pints on the board, it stopped. Hope this helps!
Nov 11, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Power
same problem here
Dec 20, 2007 | Pioneer SD-P50A3-K TV
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
620 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
