Question about Westinghouse L1975NW Monitor
Westinghouse L1975NW monitor: all of a sudden it display the bar that switches between "Text Mode" "Picture Mode" and "Economy" continiously. There is Exit button on that bar but my cursor cannot get there. I don't know how to stop it
  • 1,684 Answers
One of the button across the bottom of the monitor is stuck. You need to just move the buttons on the bottom around a bit and then power it back on. Your problem should be corrected.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 15, 2009
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
L1975NW monitor will power on but no image will come up. computer works with older monitor.
When you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "enable vga mode" then go to display property in control panel.Then change screen resolution to 1024*768 then apply you can also change the display from there. You can change desktop background and other display settings from start menu->control panel->display.. Let me know if you need further assistance. Thanks for using FixYa.
Aug 28, 2010 | Westinghouse L1975NW Monitor
DVI-D cable not working with Westinghouse L1975NW...
If the monitor has two video inputs - a DVI-D and a DSub VGA then the monitor needs to be switched to the DVI-D video input.
Jan 26, 2010 | Westinghouse L1975NW Monitor
L1975NW Monitor will eventually light up a boot up
your cold cathodes (tiny fluoresent lamps) and, the inverter (ballast) board in the monitor's screen; need to be replaced
Jul 01, 2009 | Westinghouse L1975NW Monitor
No display
I bought an Acer V193bm. If I manage to get the Westinghouse fixed, I'll post about it.
Jun 16, 2009 | Westinghouse L1975NW Monitor
Monitor has wrong resolution suddenly
probably the accessibilty options are being used..look at this article:http://www.ictknowledgebase.org.uk/vistaaccessibility
in XP they are called "Accessibility Options
hope it helps!
Oct 31, 2008 | Westinghouse L1975NW Monitor
Westinhouse L1975NW Monitor
You can check your monitor .Restart your system and press F8 till it appears "safe mode" then select safe mode and press enter if display comes.then run your system on that LCD monitor.When desktop appears right click on desktop blank area then select property option.then press setting tab and select advanced option.Then select monitor tab in next window and select minimum frequency(ex-60 hertz).
Feb 29, 2008 | Westinghouse L1975NW Monitor
No input...
spacer.gif spacer.gif spacer.gif spacer.gif Service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
Note regarding LCD Drivers
Since Westinghouse LCD (TVs and Monitors) are plug-and-play devices, they do not require any drivers. If your computer is unable to display at the recommended resolution, please check your graphics card to see if it supports the recommended resolution. You can periodically check the graphics card manufacturer's website for any update.
Good Luck, Please dont for get to Vote. Thank You.
Dec 12, 2007 | Westinghouse L1975NW Monitor
Westinghouse L1975NW Monitor Logo
134 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
