Question about HP Pavilion dv6000z Notebook
The Optiarc DVD RW AD-7561A ATA won't work on hp pav dv6000
When I go into the device manager it tells me that I have the most updated software available, but it also acknowleges that the program cannot run. When I search for solutions, it thinks about it for awhile and then nothing.
  • na_boster Feb 16, 2009
  • Anonymous Mar 28, 2009
    same problem here
Optiarc dvd rw ad-7561a ata device unplugged
Check BIOS for Optical drive. Press F key noted on boot screen to enter. If it's not noted there, you need to check physical connections. Might just need to be re-seated with power disconnected. Re-check BIOS and make sure to save before exiting.
If it is noted in BIOS and Windows still fails to see the drive. Run a thorough virus scan, then boot into Safe Mode by pressing F8 during startup. Go to Device Manager, and select Show Hidden devices under the View tab. Delete all drives and reboot. Windows should say new hardware found and install.
This should take care of the problem if there is nothing wrong with the drive. Replace or seek professional support is not, and good luck
Dec 11, 2012 | Computers & Internet
My optical device needs drivers
Optical drives don't need drivers, they all use the same generic driver that comes with Windows.
Jun 12, 2010 | HP Computers & Internet
Windows vista updated and now my optiarc dvd rw drive won't work
You will have to uninstall the drive and reinstall again. I think the drivers for the drive is not properly installed. But if all this does not work, then I think you will have to do a system restore.
Best wishes
Oct 29, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Hp Pavilion dv6000's dvd-rw won't work
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
Feb 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Windows uses generic simple drivers for any optical drives. Try deleting the drive from device manager and reboot. You do not need to download anything special for windows to operate a drive. If you cannot access the drive then it may be damaged or a hardware fault.
Jan 25, 2009 | Computers & Internet
Optiarc DVD RW AD-7561A This device cannot start. (Code 10)
Go to this incredibly long link (sorry about that) and look though the solutions there, it says it is for hp and sony computers but it has the same principal for all dvd/cd drives
I hope this helps
Dec 19, 2008 | eMachines T5274 Desktop PC
I beleive that this code is being displayed under the Device Status in the Properties window of the DVD Drive in Device Manager.
If it is so, you need to do some modifications with the Registry to resolve the issue and I am sure that the issue will be resolved with this.
However, since you had not specified the Operating System which is installed in the Notebook is Vista or XP.
However, I am providing the links which includes the steps for both Vista and XP to edit the registry to resolve the issue with Error Code 10 with the DVD Drive in your Notebook.
Removing Upper and Lower Filter in XP :
You need to perform the steps listed under Advanced Troubleshooting to delete the Upper and Lower filters.
Removing Upper and Lower Filter in Vista :
You need to perform the steps listed under Resolution in the link above.
You may not find both the Upper and Lower filters according to the instructions links provided above.
Delete the ones among the Upper filter or Lower filter or both which you find in the locations mentioned.
This should solve the issue...
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
289 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
