Question about Danby DWM5500 Front Load Washer
I have no manual
Would like to know where the soap and softener go in the tray and which is the bleach holder
  • 8,197 Answers
Here you go. on the right you can download the manual.
http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DWM5500W-_E
Good Luck and Please Rate FixYa!
Posted on Jan 10, 2009
Samsung washer softener
2 possible reasons for your issue, you might be filling the softener compartment too full, or possible pushing the tray in too forcefully causing the siphon action to occur which empties the compartment. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
I just moved into an apartment and have a Bosch front load washer and dryer. I'm not sure if I'm putting the soap, bleach and fabric softener in the correct trays . There are three slots and I
I am not sure of the dispenser trays but if the clothes are taking to long to dry and are still damp, check the vent hose and the duct work going out the apartment for lint buildup.
Oct 14, 2012 | Bosch Axxis WFL 2060 Front Load Washer
My washer is leaking detergent from the tray on the front of the washer. I cannot find anything online to help.
YOU MEAN THE TRAY WHERE YOU PUT DETERGENT, BLEACH, AND FABRIC SOFTENER IN? IF SO, REMOVE THE TRAY OUT COMPLETELY. REACH INSIDE MAKE SURE THERE IS NOTHING IN THERE THAT COULD BLOCK THE WATER GOING INTO THE MACHINE VIA A HOSE. AND ALSO CHECK AND CLEAN YOUR TRAY. THE TRAY CAN BE DIS-ASSEMBLED TO CLEAN. RUN IN WARM WATER AND MAKE SURE YOU CLEAN THE WHOLE THING OF SOAP AND SOFTENER RESIDUE. DON'T FORGET THOSE TINY LITTLE HOLES ON THE TRAY AND THE REMOVABLE CAPS
BOYNISMO@YAHOO.COM OR 714-334-1998
Dec 09, 2009 | LG WM1812C Front Load Washer
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Sears / Kenmore top-loading washer does not dispense bleach
Remove the tray and check the proper operation of the solenoid for the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore 23822 Top Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Danby DWM5500 Front Load Washer Logo
268 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
