Question about Motorola Mobility i710 Cellular Phone
Can not send messages with motorola i710
I just got me a motorola i710 , in the menu do not show tex messagin.... can i tex message with it?
  • Anonymous Mar 29, 2014
    my device don't send tex messages
Mine does not show this either, I have a i710 Nextel I am using with Boost Mobile as we speak, I have to open my web browser and select text messaging and do it all from there...Try a master reset...If not after that, it's not there, I am not sure where to go from there..Hope I helped a little.. Good luck
Posted on Jun 12, 2009
    Sergeant:
  • 431 Answers
Try formatting the phone
Posted on Jan 10, 2009
SOURCE:
I cannot send tex messages.i can only receive messages.
Take menu in your phone Messaging--> options--> settings--> text message--> Msg center in use--> Please tick the sim message center preffered connection - set it as gsm or cdma - as per your network opeartor. The try agin sending messages :D
Jan 28, 2011 | Nokia 6600
Im having trouble texing from my phone nextel i710
Hi, am sure the problem is to your sim card (network), not your samsung cell phone. In most cases, regarding text messages, the problem is from the Service Operator. Have you tried the sim card on another phone? If not, remove the sim card, insert it on another phone and try sending a message from another mobile to you number, or you can do it in vise versa by inserting another sim card on your mobile.
If you can't receive text messages even it's inserted on another handset, then you need to call the customer care of your Network Operator and tell them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think it's very much important in your case, well, if you wanna try, just check the text message settings and verify that the message center number (which is currently in use) is the same number which is on another phone with the same network (the other sim should be of the same network in your area). If it's different, make the changes and save the settings. Also disable the "Receive Via" or similar settings.. (I can't recollect the exact settings as i don't have the same model with me, please excuse me for this.).
If the same sim card doesn't receive text messages using another handset, don't bother to change the settings or to make any changes with it, first call the customer care and verify from them, you may make mistakes instead of fixing it.
Have a nice day.
Sep 01, 2010 | Nextel i710
All of a sudden I cannot make outgoing calls from my Motorola i265. ''message, the number you have dialed is temporary out of service'' which is not the case. It happens with every outgoing number I dial.
check in the top right corner of the screen. if it shows a phone icon with a 2 next to it, you are trying to call out on the wrong line. go into menu=> settings=> phone calls=> set line. make sure set line is on 1.
Jul 10, 2009 | Motorola Mobility Naztech Nextel Iden...
I can recieve text messages but when trying to send one I get "NO CENTER NUMBER" on screen.
to see if there is a center number well it kinda depens on what fone u have go in the menu and go under messagin setting and it shud say txt messaging and then senter address there shud be on there but idk what kinda fone u have so it mite not worke for u so :( srry
Jun 16, 2009 | AT&T Motorola c168i Pay-As-You-Go Cell...
Trying to send a text message from the nextel I710 motorola phone but text message is not an option under messanger center list how do i send text?
To send a text message for the i710, you may need to go to WEB, and go to send text message, there should be an option for this. Recommended that you get a texting package, due to it may run $0.15-0.20 per text. Let me know how it goes,
Thanks
Justin
Please Rate Me :)
Jan 09, 2009 | Nextel i730
How to take off text message signatures nextel i710
I have seen this issue MANY times before, what I can recommend for this exact problem, is to Reset to Defaults. Which will delete all your Downloads/contacts/saved info. This option should be located in menu-settings-security, password should be 000000 unless you have modified it. the option will either be, Restore Defaults, or Reset to Defaults.
Let me know how it goes, thanks
Justin
Please Rate Me :)
Nov 23, 2008 | Nextel i730
Help can't send out texts
hpefully you are putting the areacode before the cell number before you send out msgs e.g areacode 246 then cell number 000-0000.
to reset the phone
menu/settings/scroll down to master reset/master clear then enter the default security code 000000
Dec 26, 2007 | Motorola Mobility W375 Cellular Phone
Problem
Make sure you have the contact saved with area code. 555.555.555
Oct 15, 2007 | Motorola Mobility Moto Q
I530 text messaging issue
To be able to send and reply to text messages you must have NOL net access. Press menu(left of the left arrow key), scroll to net, press ok(if an error message appears contact nextel for internet service), scroll to text messaging, press ok. From there you can write, read and reply to text messages. The reason for having to do it this way is because this phone as well as others with nextel were being produce when text was first being introduced to nextel, at that time motorola wasn't making nextel phones with the option of text, so it was up to the provider to give text access(via. net).
Sep 25, 2007 | Motorola Mobility i530 Cellular Phone
Predictive text
Aswer is in the instructions, you can download off the internet.
http://support.t-mobile.com/knowbase/root/public/tm30114.pdf?&A2L.SERVICE=Manual&WT.srch=2&Result_Inq=answer&InqSource=TMO
1) Go to text entry screen (txt message screen)
2) Push the _ button at the very top middle of your phone.
3) The Message menu will open, go to Entry Setup and set your Primary Setup to TAP English.
This will fix your problem, I set my secondary Setup to Tap Extended.
I have just done this and have not given it a major examination, but I can send text messages now without any bother.
Sep 21, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility i710 Cellular Phone Logo
329 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
