Question about Water Heaters
C7 76 errors on RMNG-74PVN - Water Heaters
  • cdhollis
    cdhollis Dec 02, 2012
    Correct model number is RMTG-74PVN-2. I contacted Rheem which is the parent company for my Richmond water heater. They sent out a new circuit board. I replaced it yesterday and it is working fine!
  • Water Heaters Master
  • 5,245 Answers
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Dec 29, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Indoor Paloma water heater showing error message C2 31 - there is no hot water. Any idea? Model #: PTG-74PVN
that is the water inlet temperature sensor fault.. check and clean scale from sensor or have it replace by a qualified technician
Jul 18, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Paloma tankless ptg42 water heater error code c4/13
4 error message, the 4th (last) error code is #13, not enough oxygen.
Check the location of the heater, if it is fine the ODS sensor (actually is a thermal couple) is bad.
Dec 25, 2009 | Rheem Paloma Tankless Water Heaters...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Nov 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am getting error code -0 and 82 PTG-74PVN
Remove power, disconnect remote terminal. Restore power, open a hot water valve and see if you get any hot water.
HTH,
Mike
Nov 15, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Paloma PTG-74PVN and I ain't getting any hot water and its showing c2-11 error code. How can i fix this problem
could be overheat stat or fan check the little hose at the fan area for pinhole next choice diaphrapm valve then micro switch best of luck
Oct 23, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
What is error code c2 76 for rtg-74pvn-2
Lost comm. between the remote and the burner control circuit board.
Sep 20, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
