Question about HP 418446-001 - HP Special Edition L2000 Series Full Featured Laptop Systemboard for
Change boot sequence for HP L2000
Replaced old hard drive with new hard drive and need to change the boot sequence so that CD drive is recognized.
HP L2000
  • 827 Answers
You need to enter BIOS at startup. The correct key to press will be displayed at the bottom of the black screen when you bootup. Usually, F10, F8 or F11 or Del. Mash them all on booting up.
Now navigate the Bios settings with the arrow buttons and select cdrom as 1st boot device with the enter button. Then Save and Exit.
Fixya!
Chris (ziraffa)
Posted on Jan 10, 2009
Boot sequence for compaq evo n800 laptop
You need a system disk first of all. Put the disk in the drive, turn the computer off then reboot. Watch the screen for which key it says to hit to change the boot sequence or boot order. Hit that key when it is shown. This is a one time solution that is only for the current boot process.
To make it permanent, boot the computer an notice what keys it says to hit to get into the Bios or System Setup. Hit that key when shown. You can change the boot sequence or boot order and make it a permanent change in the bios. The most common and best boot sequence is to have the CD drive 1st and the Hard Drive 2nd. Just make sure no disk is in the cd drive when you boot it up or you will get a error saying no boot record or system disk found.
May 01, 2012 | HP Compaq Evo n800c Notebook
Won't boot and cd read light flashes on and off
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 01, 2011 | HP 418446-001 - HP Special Edition L2000...
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
Hard drive died & replaced with a new hd
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
May 29, 2009 | Dell Latitude D505 Notebook
Computer doen't recognize Maxtor n256 have to boot by CD
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears.
  4. you should see the maxor disk (unallowcated)
  5. right click & format it
Apr 04, 2009 | Maxtor Hard Drive
Keyboard is stuck and need change boot order
You can try connecting an external keyboard. When the external is connected the BIOS may ignore in built-in keyboard, bypassing your keyboard error.
You can also try removing the stuck key by prying it up GENTLY.
The answer to your question is unless you can get a working keyboard connected to your computer there is no way to change the boot order. Without a working keyboard you can't get into the system setup (BIOS), nor can you press the correct key.
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
Machine won't recognize CD-ROM after harddrive format
When booting up select whichever key gets you into the Bios. Normally either F2 or delete. Once in the Bios, find the boot up sequence and by the instructions that will be there to change the sequence change it to Floppy Drive, then CD Rom, then your hard drive with Windows on it. Press F10 to save and reboot.
Nov 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Need help!!!
depending on the brand... you need to press a function key (F2, F9, F10, or F12 keys) to get into the BIOS and you need to change the boot sequence to start booting on your CD or DVD drive. but the operating system disc should be in the disc drive before doing this.
Jun 03, 2008 | HP Compaq nc6230 Notebook
I think my compaq presario desktop has crashed
the computer is not recognizing the contents of your hard drive. you'll need a floppy with command.com, iosys.com and sysinfo.com on it. when inserted into the drive cmos looks here first. if you can access the cmos, check the search parameters to see what the computer boot up sequence is. you may want to change it to recognize the cdrom first, then the hard drive, then the A drive. I had a compaq armada that gave me the same message but I was able to reformat the drive off DOS 6.2 and changed the boot up sequence.
Dec 28, 2007 | Computers & Internet
HP 418446-001 - HP Special Edition L2000 Series Full Featured Laptop Systemboard for Logo
603 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
