Question about Sony KL-50W2U
Sony KL-50W2U rear projection TV stuck in standby
Brought this Tv second hand without a remoute was working fine last night then my partner put it on stand by and unplugged it over night (as we did with our old TV) and this morning plugged it back in and tried turning it on but the standby light just comes on (doesn't blink) and nothing else happens
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Try holding down the power button until it turns off and then turn it on again.
Posted on Nov 29, 2012
  • sarah_axton
    sarah_axton Nov 29, 2012
    The television turns off ok when turn back on it still on stand by mode thanks
5 Suggested Answers
  • 48 Answers
SOURCE: Sony KF-50WE610 LCD projection TV. no picture but flashing green
Replace the lamp as they dont last for long
Posted on Feb 01, 2008
  • 23 Answers
SOURCE: Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank me...lol...
HOPE THIS HELPS!!!! IT WORKS, TRUST ME...
Posted on Oct 01, 2008
mistersony
  • 320 Answers
SOURCE: model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
Posted on Oct 26, 2008
SOURCE: Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Posted on Sep 12, 2009
Sony kp41s5u rear projection tv constant blinking standby
Power supply or set is not allowing set fully on as a problem in any of a number of areas in the set. Try unplugging set for a while to see if that helps or have a tech look at it.
Dec 23, 2012 | Televison & Video
I have a sony grand Wega KDF-kdf50e2000 and when you turn the TV on it will work fine for 40 seconds and then go off with the green power/standby indicator flashing. After 40 seconds the TV will come back...
you have a ballast issue this is a common failure for LCD rear projection read this link and you will see why I think this
http://www.fixya.com/support/r3556856-how_to_know_if_it_is_the_lamp_or_ballast
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The TV went on standby last night, the TV was then switched off at the mains last night and then this morning it seems to be stuck in the standby mode - can you help?
Replace both of your STK ICs they are big black ICs will have part number on them STK392-020 or 040s also replace 2 resistors 2.7ohms in front of ICs Call Mats Electronics for parts 1-800-628-1118
Dec 29, 2009 | Samsung HCM4215W 42" Rear Projection...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
My tv will not turn on
Almost certainly the lamp. You should be able to get the # from your instruction book.
Mar 30, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Video
How many times does the light flash?
Sep 28, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Won't turn off unless unplugged
Ther eis a stand by function on the Television. If you have the owners manual read about that function. Th ered light stays on because it is programed to come on a t a certain time. Go to menu and find the stand by function.
Aug 17, 2006 | Sony KP-51HW40 51" Rear Projection...
Sony KL-50W2U Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
