Question about Samsung S5620 Cell Phone
My s5620m goes off and battery is full - Samsung S5620 Cell Phone
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Probably a loose battery connection or a short. Make sure the phone is dry and the battery pack is securely fastened.
Posted on Nov 29, 2012
    New Friend:
  • 47 Answers
You must change the battery.
Posted on Dec 03, 2012
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
My car doesnt start
Sometimes the battery will be good enought to run lights but will not turn car over. I would have battery put on a full charge and see if it holds up. if battery will not hold a full charge it is bad. If your car runs and the battery last a few hours then goes low again, It most likley is the alternator. put battery back on full charge and replace alt, and you are ready to run.
Apr 11, 2012 | Cars & Trucks
Anomalous charging behaviour :- a) plug in discharged battery b) starts off with the yellow light flashing as usual c) after a very short time the lamp goes off completely - instead of staying on...
Okay, might not be reading this right but here goes. If the camera shows the batteries as full then I'd go with that. The charger will come on for a few seconds even with a freshly charged battery because it take that long for the charger to realize the battery is already full. You can't feed an already full battery, so the charger is shutting off completely. Yes normally the light would stay on and the charger would continue to trickle a charge into it it until it is removed. In your case I think you have those batteries stuffed to the gills so the charger is shutting right down. One of the problems with these batteries is as much as the manufacturers deny it they form a memory. Best thing to do with these rechargeable batteries is drain them right down and then replace with a freshly recharged battery.
Dec 17, 2010 | Nikon MH18a Battery Charger
My nokia e61i charges for a small period of time and full battery
i think you have to replace the battery, and try to buy the original or genuine battery.
Apr 10, 2010 | Nokia E61i Cellular Phone
Shows full charge,goes ok for a little while but then stops turn off then on goes very slow for seconds then stops again.
Hi Susan, I repair power wheel chairs, Its possible that your chair has a bad battery on it , all p/chairs have 2 batteries.And even though you show a full charge one battery may have a bad cell in it you need to get both batteries load tested . I think you my find one of them bad. take them out of chair and have them tested.You can get replacement batteries , and have yours tested at a store that sells batteries only, look in yellow pages for a battery store . Good luck, Erik
Mar 01, 2010 | Electric Mobility Shoprider Electric Power...
My HTC Touch display goes blank and phone doesn't ring
Ok,
Good to read the detailed description. You said, the battery is full but did u checked the battery healthiness. Is it really full. Put the battery in another set if you have because the true picture will be in front when u check the battery on load condition. You can check the battery voltage but it might show you the full desired volt but without load. So, the better way has mentioned.
Tell me one thing that was it going off when u swap/filip ist screen. If this is the case, then u need to check the strip that connects the keypad of your phone with the LCD. This can be the issue...
good luck...
Sep 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
1999 lincoln washer light stays on battery light goes on and off
disconnect the battery for 10 seconds but you might need the code for the radio after you disconnect the battery.
Dec 18, 2008 | 1999 Lincoln Town Car
Samsung S5620 Cell Phone Logo
55 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
