Question about Garden
Replace pullcord on troy built mower
The model # is 8654r troy built 4 hp mower. I need to replace the pull cord. Thanks
  • 1 more comment
  • jimgunn Jan 15, 2009
    the pull cord is on the very top . theres no need to remove the tank. i had to remove 4 rivets to remove the pull cord houesing. thanks anyway
  • chrishuff01 Apr 17, 2009
    how do you remove the rivets?
  • Anonymous Mar 21, 2014
    replacing Drive Belts
    President:
  • 1,388 Answers
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
I have a troy bilt 21" push mower. Model no.11A-436M01198557. While changeing my pullcord the coil spring came out. How do I reset and put back in houseing
slip the spring through the rope hole attach it the rope pulley and wind it clockwise the spring will be pulled in make sure you set spring in its groove on the outside of cap the tighten it up by winding then let uncoil in cap
Jul 09, 2014 | Garden
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
How do I replace the pull cord on the Troy Built Mower model # 12AI867Q011 serial # 1E098KC0419
You have two options. look up your models starter assy. at a dealer like www.arcolawn.com and replace it as a whole or purchase the rope remove the starter, charge the spring by twisting it all the way tight, back it off one turn and install the new rope. Tie your knots and reinstall the starter.
Thank you
Joe
Oct 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed...
sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Jul 25, 2009 | Garden
Troybuilt selfpropelled mower Model # 8654R
You can go to Troy Bilt website Customer Solution Center. There you can view/download and print owners manuals. I found the detailed solution to my question there. Best part...it's FREE!
Apr 12, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
1,008 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
