Question about Proview HX303 30 in. HD-Ready LCD Television
Proview hx303 the screem is half white and the other half black
Only show half of the screen
  • highlander12 May 11, 2010
    On the TV screen is one side completely blue? Is the other side the complete picture of what you are watching?
    Problem Solver:
  • 21 Answers
SOUNDS LIKE A DEAD PIXEL KIND OF PROBLEM OR SOMETHING TO DO WITH HOW THE SCREEN IS TRANSLATING THE POWER ITS BEING GIVEN THEREFORE NOT GIVING A FULL SCREEN DISPLAY. AN INTERNAL ISSUE I WOULD CONTACT THE COMPANY ITS MADE BY AND SEE IF THIS IS A COMMON PROBLEM THEY MAY HAVE A RECALL ON OR SOMETHING THAT CAN STILL BE COVERED BY SOME KIND OF WARRANTY
Posted on Jan 10, 2009
Proview hx303 .....it will turn on for a few seconds and then turn off....has sound ......slight buzzing sound from the back
had one where back lie was going out turned out to be bad solder on transformers
on the board that feeds the lites
Aug 28, 2011 | Proview HX303 30 in. HD-Ready LCD...
32inch proview lcd tv has a green square instead of a picture,but i get the sound .?
if you are getting color on the screen, chances are that you might have a cable loose. I'm not sure if you are using component cables but sometimes when the blue cable is loose, it will cause a green screen. or if you are trying to watch something above your TV's capabilities, this will happen as well.
May 04, 2010 | Proview HX303 30 in. HD-Ready LCD...
Black mark on screen
The only way is by changing the panel.
Apr 07, 2009 | Proview HX303 30 in. HD-Ready LCD...
No picture only sound
I think you might have dry solder joints on the line output stage but if this does not solve the problem then it is a faulty component on the line output stage. If you can do it check for yourself otherwise find a competant technician. Hope this helps.
Oct 03, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview HX303 30 in. HDTV-Ready LCD
Inverter board is tripping protective circuit. Check Caps!!! or Ballast's.
Jan 29, 2008 | Proview HX303 30 in. HD-Ready LCD...
No picture No sound
i found bad connections between 24volt supply and main board. resoldered 2 pin connector on main board, squeezed ID connectors and has worked fine since.
Dec 28, 2007 | Proview HX303 30 in. HD-Ready LCD...
Proview mnufacture code
Try these 0835, 1401, 1498, 0001, 0178, or 0030; these are what I have foudn from 10 different web sites. No answerr from Proview tech support
Oct 15, 2007 | Proview HX303 30 in. HD-Ready LCD...
Proview HX303 30 in. HD-Ready LCD Television Logo
104 people viewed this question
Top Proview Televison & Video Experts
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
