Question about Vacuums
Vax mach air reach
What has happened is that the kid s jammed toys down the telescopic handle so i took out the base screws and opened the power switch unit to releve tension to lift up the back to get the toys out tugged too hard and the four leads connected to the switches have popped of they clip on no problem but where do they go?? each switch has two connections marked 1 and 2 one is the power and the other is to switch to hose function which is marked 1 and 2 also theres a red and and a brown looped to gether and one single brown and another brown linked through a blue any help would be great thanks
  • 6 Answers
You might be having problem in following area 1. Check the cable first. You can use the cabe tester. If cale tester is not available then chek the cable with multimeter. 2. Check the port wher you have inserted the patch cord. It should be in uplink port of first hub and normal port of second hub. Try this and revert back with results.
Posted on Jun 26, 2007
  • 1673 Answers
SOURCE: E series power head handle, internal wire came lose
Here is a pix.
Posted on Feb 12, 2008
SOURCE: bissell lift off pet-no suction through base (hose is fine)
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
Posted on Jun 15, 2008
  • 1314 Answers
SOURCE: Kenmore Lid Switch Bypass Test
put a jumper wire from blue to pink
Posted on Jul 08, 2008
  • 848 Answers
SOURCE: jenn-air range model S136C
just go through the manual it will have digrams of how to give connection .........
Posted on Aug 26, 2008
How do I change the belt on my vax Mach air u91-ma-b
goto this link and on the page i think your manual and hoe todo it is the forth one down.... How do change the belt on my vax Mach air u91 ma Google Search
Dec 12, 2016 | Vax Vacuums
I have a vax mach air u91-ma-b where's the drive
click on the link below and you can dowload the manual witch will give you instructions how to change the belt
Mar 20, 2013 | Vacuums
Vax mach air reach suction problems
Thanks to N3FAR. It was very helpful, i have been callinv Vax and they are asking me to do all sorts of other things. Thanks you again
Dec 31, 2012 | Vacuums
Vax mach xp reach seems clogged and light is on
Clean the filters as per the user guide AND remove the silver, where the clear plastic handle is. On te back by the purple catch to release the dirt container is a screw - remove that and then remove the 3 screws on the purple lid with holes in it, remove the lid & clean the "cyclones" - mine were all blocked. Make sure all the bits are clean & dry & re-assemble.
Jul 29, 2012 | Vacuums
Roller brush not working on vax air mach 6
Hi I have a vax mach air light.the brushes wont turn but the green light is on. I have checked eveything .The little button on side tube no blocks .Checked all filters.
Jul 07, 2012 | VAX Appliances Vax X3 Bagless Upright...
How to fix red light flashing on my vax mach air pet and family
If you make sure that the roller is clear you just press the button near the left wheel that says 'Brushbar reset'. This worked with mine straight away. :)
Jan 03, 2012 | Vacuums
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
