Question about LG 26LH2000 26 in. HDTV LED TV
In my tv ther s no audio analog output ,there s only optical fibre output ,is it possible to get audio output by using fibre optic receiver ?
2 Suggested Answers
SOURCE: how do i get audio output from a LG 47LD520 with
Either use the white/red analogue audio outputs on the TV.
Or, you can get a Toslink optical to coaxial audio converter for $10 - $15 off ebay. http://cgi.ebay.com/TOSlink-Optical-COAX-Coaxial-Digital-Audio-Converter-/220657947104?pt=LH_DefaultDomain_0&hash=item33603d11e0#ht_1128wt_1139
Posted on Nov 09, 2010
How should you connect your CD player to your av amp (both Technics) using an fibre optical cable?
It sounds like your CD player does not have an optical audio output. If so, you will need to get a "Digital to Analog Audio Converter". You can find them on eBay or Amazon for as little as $10. Connect your CD player's analog/RCA-style stereo cables to the converter.Then connect the converter to your receiver with a single optical cable. 6_20_2016_11_27_39_am.png
Jul 01, 2015 | Audio Players & Recorders
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Smart led manual
optical or digital if amp has these connections
Sep 02, 2014 | Audio Players & Recorders
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
Feb 10, 2010 | Yamaha HTR-5740 Receiver
Denon DHT-500SD system and want what is on TV to come through 500
You could try the optical route. You should be able to use the analog RCA audio outputs of the TV to the analog TV or VCR audio inputs of the receiver as well. Select the appropriate input on the receiver and you should have TV audio.
Jan 02, 2010 | Denon DHT500SD System
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Optical audio from cable box to receiver
Do you mean the optical digital audio output from the cable box? This is so you can listen to Digital sound from cable tv broadcast, First go to the cable box remote control, select setup or menu to find audio, then select audio output, check digital audio, not mts or stereo, this should enable to optical output instead of the typical 2 channel red and white left and right RCA analog audio outputs, sometimes different cable boxes vary, but most require you to enable the optical output via the method listed above.
Jan 28, 2009 | Yamaha HTR-6140 Receiver
LG 26LH2000 26 in. HDTV LED TV Logo
57 people viewed this question
Computer Repairing
Computer Repairing
