37 in. Viewsonic TV volume steadily increases up to maximum 100. unable to control it until i pull the power plug
  • Mike Dec 01, 2012
    Specifically for the Viewsonic N3752 w I held down 2 volume buttons at the top of the TV together , this does a menu lock that is displayed on screen, repeat the procedure to unlock. This seemed to work. I now can control volume through either source.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Either the button is jammed on the remote or the TV itself. Try removing the batteries from the remote. If the doesn't work, it is probably the actual button on the TV, in which case you would have to try and pry up the button and manually pull up the pressure pad underneath.
Posted on Nov 29, 2012
ohms
  • 1879 Answers
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Posted on Sep 30, 2008
javswr
  • 44 Answers
SOURCE: Volume increases by itself
This could be a sticky button or a bad key controller! The key controller is the button board, this stream the commands to the main board (main unit). not to hard to replace, if your somewhat handy! But will require the case (back panel) to be removed. Good luck, hope this is helpful!
Posted on Mar 02, 2009
Apparently this seems to be a known issue for this model. I called Phillips and they did not even bother asking me to try things like switch off and on again etc...They just said they are going to send someone to pick it up and fix it. I would suggest to everyone to do the same since it has to be free of charge because the problem appears in pretty much every tv set of this model.
Posted on Apr 28, 2008
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Posted on Aug 17, 2009
How do you increas monitor sound?
Check the settings for audio volume control on the monitor side. Also, check the individual settings for the audio for applications and system sounds on the OS side. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
I have a 42PC5 LG Plasma, and the problem is that the TV Remote control and Buttons (on the TV) are not working/responding. The only way to close the TV is by plugging out the Electricity Cable, and when...
i think that there is a shorted buttons or in normally close position, try to press each buttons slowly and you will feel something that is ticking if one of the buttons does not tick it is damage it is in normally close position that will be the cause of the problem. specially check the volume button.
Jul 02, 2011 | Televison & Video
How to increase max vol further on, of my laptop gateway mx6956 as it is horribly low
Hello, You can increase the volume of your laptop by, first check the speaker and headphone icon whether it is set to 100%.You can see it in the system tray or by the right hand side at the bottom of your screen or at the control panel,click on SOUND and increase the volume. Note the software you are using like window media center, VLC player, real player and the likes should also be increase to maximum, then if your computer has an external control for the volume, make sure you increase it to the maximum. HOPE THIS HELPS
Nov 23, 2010 | Gateway MX6956 Notebook
Having connected up my PVR915OT I am unable to increase the volume on the TV to a reasonable level of volume using the Humax handset- can you offer a solution please?
As far as I recall, the volume control on the PVR remote only controls the volume from the PVR. So, select the volume fully up (using the PVR remote) then increase the volume on the TV (using the TV remote) until it's as loud as you can stand. You can then adjust (decrease) the the volume to suit using the PVR remote.
Jan 13, 2010 | Televison & Video
How do I change the power supply for my Viewsonic 37'' Model # N3760W LCD TV. It keeps turning off when I change channels and adjust the volume. I cant order one from Viewsonic.
Very carefully. I only would do it after you have verified the warranty is expired per Viewsonic. If it is OOW, then you can call them for a service manual that contains schematics, troubleshooting flowcharts, etc.
Dec 27, 2009 | ViewSonic NextVision N3760W 37 in. LCD...
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Random volume increase to 100
It sounds like you have a defective Main Control board. I would contact a service co. as soon as possible.
May 02, 2009 | Insignia 42" LCD Flat-Panel HDTV
Jun 14, 2008 | Sharp LC-26D43U Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
