Question about Cell Phones
How to remove sim card from nokia x3-02 - Cell Phones
    New Friend:
  • 23 Answers
1.Insert a SIM card. Make sure the contact area of the card is facing down
2.Press the release buttons, and remove the cover. If the battery is inserted, lift the battery out.
3.Line up the contacts of the battery and the battery compartment, and insert the battery. To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
how to remove sim card from nokia x3-02 - 11_29_2012_6_43_26_pm.jpg11_29_2012_6_43_52_pm.jpg
Posted on Nov 29, 2012
Nokia ce0434
Remove the batter case, remove the battery, pull the sim card slot gently, pull out the sim card.
Jul 11, 2014 | Nokia Cell Phones
Need to remove sim card
Nokia Lumia 920 has a SIM tray on the top of it. You need a needle or a clip to open it.
If you need to put in a different SIM card in the device you should first make sure it is unlocked to the network provider. SIM unlocking will enable you to use your device with other SIM cards from other carriers. To Unlock Nokia Lumia 920 you need an unlock code. Follow the Link to know more about Nokia Unlocking.
Apr 22, 2013 | Nokia Lumia 920
Pls how can i flash my nokia N95
No matter what network your Nokia N95 phone currently runs on, you can unlock it---or "flash" it---to run on any GSM network. You will only be able to use your unlocked Nokia N95 phone on networks that use SIM cards---such as T-Mobile and AT&T---and not on CDMA networks such as Sprint and Verizon, which do not provide SIM cards.
Read more: How to Flash a Nokia N95
Unlocking the Handset
Remove the back cover and the battery from your cell phone. Locate a silver sticker with a bar code on it. Take note of the 15-digit IMEI number printed on it. At this time, also remove the SIM card and write down the numbers printed on the back of it. The SIM card is the small, white data chip in the silver cradle right next to the sticker. You will need these numbers to obtain your Nokia unlock code.
Request a Nokia N95 unlock code from your service provider. If they cannot provide you with an unlock code, you can buy one online.
Replace the SIM card, battery and cover. Fully charge your handset.
Turn on your handset and type "#PW+".
5
Enter the unlock code given from your phone company or website. Make sure you dial the number exactly as it was given to you. If you dial this number incorrectly three times, you will be permanently locked out of your handset.
6
Dial "+1#". At this point, the screen on your Nokia N95 should read "SIM Restriction Off."
Inserting SIM Card
Switch your handset off and remove the back cover and battery.
Remove the SIM card.
Insert the new SIM card into the SIM card slot. Now that the phone has been unlocked, this can be a SIM card from any U.S. service provider that uses SIM cards.
Replace the back cover and battery and switch the cell phone on. The screen should now read the name of the new service provider
Nov 30, 2011 | Nokia N95 Cellular Phone
Insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
How to remove sim card from nokia c7
RIGHT SOLUTION: To remove the SIM-card, press the SIM-card a bit further down the slot (with another sim-card, a memory card, your nails if they're long enough,...) and then release the pressure. The SIM-card will come out far enough for you to pull it back out.
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
I want to swap sim card from one Nokia 1600 to another Nokia 1600.
As long as your second phone is not locked to a network that is different to your sim card, simply remove the back cover, removed the battery and swap the sim card.
If the second phone is sim-locked to a different network, you will need to get it unlocked
Oct 13, 2010 | Nokia 1600 Cellular Phone
I can't find the part in my phone for the sim card!
The SIM card on a Nokia 6085 cell phone is under the battery.
Remove the battery
There is a metal sim card holder located near the base of the phone.
Unlatch it with your fingernail and swing it up.
Insert the SIM with the notched corner first.
Apr 24, 2010 | Nokia 6085 Cellular Phone
How do I get the sim card out of a 3100 nokia
1.remove the back panel
2.remove battery
3.remove sim lock
by this you can remove your sim out from your phone.
*but switch off your phone before removing your battery.
Dec 15, 2008 | Nokia 6010
My cell phone nokia 1600b net10 is telling me sim card rejected what do i co
hey i've done that man and now its just saying enter sim card. what do i do next? its for a nokia 1600b net 10 phone. please get back to me asap. please. i need my phone working now. thanks
kyle benjamin
Sep 30, 2008 | Nokia 3220
Cell Phones Logo
305 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
