I need application window 7 32bit - Computers & Internet
  • 27,725 Answers
What application are you referring to post a reply and i will try be of help
Posted on Nov 29, 2012
It print all color blue
use the printer utilities
Using the Printer Utilities
how to
Accessing the printer software You can access the printer software from most Windows applications, or from the Windows Start menu.
When you access the printer software from a Windows application, the settings that you make apply only to the application you are using.
When you access the printer software from the Start menu, the settings that you make apply to all of your Windows applications.
Refer to the appropriate section below.
From Windows applications
Follow the steps below to access the printer software.
Click Print or Print Setup on the File menu. In the dialog box that appears, click Printer, Setup, Options, or Properties. (Depending on your application, you may need to click a combination of these buttons.) The printer software opens.
From the Start menu
For Windows Me, 2000, NT 4.0, 98 and 95 users, click Start, point to Settings, then click Printers.
For Windows XP users, click Start, then click Control Panel, then click Printers and other hardware, then click Printers and Faxes.
For Windows Me, 98, and 95 users, select your printer, then click Properties on the File menu.
For Windows XP and 2000 users, select your printer, then click Printing Preferences on the File menu.
For Windows NT 4.0 users, select your printer, then click Document Defaults on the File menu.
May 13, 2015 | Epson L210 - multifunction printer /...
Tip
Alternate method to access Application Recovery/Recovery Manager in HP PC
Scenario: Recovery manager or Application Recovery on your HP Desktop PC doesn't work or you are unable to access Application Recovery or Recovery manager.
Tip:
For Application Recovery:
1. Click start, my computer.
2. Open C: and Windows Folder.
3. Open SMINST folder within Windows folder.
4. Double click appinst.exe to open application recovery.
For Recovery Manager:
4. Double click restore7.exe to open Recovery Manager.
If above folder is not found. Then,
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
on Jan 18, 2010 | Computers & Internet
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
What is the difference between the Dos download and the windows download as there is 23 mb difference.
What application are you talking about?
Windows uses a different set of hardware drivers and completely different user interface software. Windows applications "call" standard methods to display menus, windows etc instead of including them inside the application. Most windows applications are larger than the dos equivalent because windows is "bigger" that ms-dos. Windows supports cutting and pasting between applications.
Dos usually has to have each application load its own drivers and its own user interface software. Often a dos application is smaller and sometimes less functional than the windows equivalent. Cutting and pasting between Dos applications is tricky and often involves "exporting" from one application and "importing" to the next via external files that you have save and locate.
Oct 08, 2009 | Computers & Internet
Some application software are not working.
You will need to install WinXP service pack 3 and some critical updates plus microsoft dot net distribution packages like" Microsoft.net 1,2 & 3". After installing them you will be able to install the various softwares you mentioned..........sodeep
Apr 25, 2009 | Microsoft Windows XP Professional
Need to reinstall my program on my emahcine T 5234
for installtion of windows, change the boot sequence of machine to first boot cd rom, the put the windows cd to computer and turn it on. the windows will install.
for applications put the application cd in cd rom and run setup of each application.
Nov 18, 2008 | Gateway Computers & Internet
Windows xp problem
Hi
It seems you installed an outdated (16bit Program) for the ScanMaker 4. 16Bit applications/programs and generally DOS based (Windows 3.x and 95) and will not run properly from Windows XP.
First, check http://support.microtek.com/product_dtl_2.phtml?prod_id=23 and download and install Drivers and Plugins for Windows XP.
You may need new 3rd Party Scanner/Image Applications that work in Windows XP. However, if you still want to use the 16Bit application then you will need to run the program in 16Bit Compatibility Mode. To do this, right-click the program executable or shortcut, choose propertise from the drop-down menu, go to the Compatibility Tab and put a tick in "Run this program in compatibility mode for:" From the drop down menu, choose Windows 95 or 98 and apply.
Finally, check the the User's Guide or ReadMe file(s) (if you have it) for more info. Especially, check the recommended OS for the Applications.
I might be wrong, but i think ScanMaker 4 has a SCSI interface. If this is correct, then your laptop or port replica must have a SCSI port. NB: SCSI is not the same as Printer LPT Port.
Regards
Mike
Mar 23, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
