I have a 50in samsung hlp5063w and i wondering what are symptoms of a bad analog video board
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
They vary but include washed out image etc.
Posted on Dec 22, 2012
I have a Samsung hlp5063w and now it has white vertical lines...is there a problem with circuit board or DMD?
hello,
Just for share, i have experience like your problem.
If your problem like picture below, thats DMD defect.
Replace it.
I hope thats will help you.
Mar 10, 2011 | Samsung DLP HL-P5663W 56" TV
Replaced color wheel and the lamp...tv still. Cycles on and off..with "lamp" green light flashing along with standby light flashing...nothing on screen and lamp not coming on? Its an hlp5063w. Please...
Since you have replaced the lamp and wheel, next would be the ballast and power supply board. These provide power to the lamp and Samsung recommends replacing both at the same time. If power supply board is bad, it can destroy the ballast so replace both. This usually takes care of the problem.
Aug 06, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Replaced lamp on samsung hlp5063w set still broke fan is definatly not running cant find replacement fan
You can get the replacement fans for your samsung at the following link. www.tvrepairworld.com you can call them to see if they have them, But they should they dont list all there parts only the high demand items are listed.
Dec 23, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hlr5667w that won't turn on. Good lamp and ballast
Any light blink on the front. Whats the voltage to the ballast from the power supply. Common problem on these sets are bad lamp door switch. Try shorting the switch. Color wheel also is problematic but usually will be noisy and cause shut down. Check power board for swollen capacitors. Hope this helps
Nov 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLP5063W no video only sound/replaced lamp 2 weeks ago
With television on and lamp lit, If you hit your menu key does it show a menu. Also just for checking sake if you are using a cable box disconnect it and using the cable coming from wall connect directly to television and try changing the source input to TV on your remote to see if anything is happens, if not then play a dvd and switch source until u hear the sound of the movie u inserted if no video, then its more then likely that the analog/Digital board assembly has failed. I don't know if you vaccumed it before it went out or after but you might want to check to make sure you did'nt hit any cables wires and loosened a plug on any of the exposed boards. If you do find one of the plugs on a board loose or not plugged snuged in its socket make sure u turn off the power first before reseating it. Also if you are using componet input for video or running video through a audio receiver make sure its set to the correct video output source. and that all cables are snug. Especially the green cable on componet inputs. If this cable is loose or comes out their will be no video.
Please feel free to leave a comment in more info is needed..
Lavell
I hope its just something simple
Oct 01, 2009 | Televison & Video
HP-R5072 50in.
If the band is vertical in nature and it goes from top to bottom then you might just have a bad address board. This requires a technician to look at it and replace it.
Jun 17, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
HLP5063W remote control
i did solve the problem,,,my "mode" button was not on TV... thanks
May 07, 2008 | Samsung Televison & Video
Samsung spp4231 plasma analog video
no video card in the tv but the main board is probably bad
Jan 12, 2008 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
