Question about Hitachi PJTX100 Multimedia Projector
I have a Hitachi PJTX100.....been using it for a year and a half and it has been flawless.....until recently....After about 30 minutes of use it shuts off....meaning the screen goes black and the actual projector light is not shining.....but the projector itslef is still running........if i unplug it for 30 seconds and plug it back in it will power up normally for about 30 minutes until it shuts off again....it just started doing this a month ago
I believe your problem is heat the bulb is getting hot and the air or fan is not working properly so when it hits temp it automatically shuts off check your fan air flow filters etc
Posted on Jan 11, 2009
Hi my projector starts up for about a minute then turns off any ideas please ? many thanks
hi,
Here i have add a link to the manual for your projector. See page number 32and 33. It describe the lamp reset and filter reset. Try these first.
http://www.manualowl.com/m/Hitachi/PJ-TX100/Manual/72291?page=33
OK
Sep 21, 2011 | Hitachi PJTX100 Multimedia Projector
How do I reset lamp time & filter time on Hitachi pj-tx100
Hitachi
  • Turn on the projector.
  • Press the "RESET" button on the remote control for approximately 3 seconds until a dialog box is displayed.
  • Select the "RESET" using the up-arrow.png button.
  • Your lamp counter will now be reset.
Jul 05, 2009 | Hitachi PJTX100 Multimedia Projector
PJ-TX100
sounds like what 80% of the projectors on this page are seeing... bad power supply or lamp ballast.
Jun 07, 2008 | Hitachi PJTX100 Multimedia Projector
Blue patch on left side of screen
I had the same problem with my Hitachi PJTX100. I discovered that there was considerable dust build-up inside the unit, causing insufficient venting of heat which then damaged the color prism/filter. It was close enough in time to the warranty for Hitachi to cover parts replacement (approximately $1,600). Since the repair, the blue patch is gone. I also regularly vacuum not only the outer cover but also the inner air filter that easily snaps on and off.
Dec 27, 2007 | Hitachi PJTX100 Multimedia Projector
Blue spots on the screen
why do i have blue spots on my grand wega small blue spots that flicker like stars shows up with black backgrounds it sounds like sony dont want to make good on there products by admitting they have a problem i had it cleand like they said witch cost me more money and spots are still there last time i by a sony.
Dec 01, 2007 | Televison & Video
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Hitachi blue patch
I've had one for about a year and a half. This is the second time it happened to me. The first time they replaced it for free(warranty). Now my warranty is up and it is starting to happen again. I think that this must be a common problem in this model. I recommend contacting Hitachi and seeing what they have to say about it. I'm yet to call them again, but I will soon.
Oct 06, 2007 | Hitachi PJTX100 Multimedia Projector
Growing blue patch
you have to replace prism it has 3 small lcd screens Green Red Blue one of them is beginning to burn they are very expensive strip projector down with no power connected and take damaged screen of then block that area so no light can pass through it with fire resistent material you will get some more life out of it
Aug 11, 2007 | Hitachi PJTX100 Multimedia Projector
Hitachi CPX275 unstable connection with Vista
Pls set up the display properties to screen reslution to 800x600 and then try higher resultion. that will work.
Viren
Jul 31, 2007 | Hitachi PJTX100 Multimedia Projector
Hitachi PJTX100 Multimedia Projector Logo
522 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
