Question about Dell Dimension 2400 PC Desktop
"STOP ERROR" COMPUTER AUTOMATICALLY SHUTS DOWN. DOES NOT RE-BOOT. JVC
    Genius:
  • 1,239 Answers
Hi
The problem might be with ur RAM.. try to remove and re-insert it.. If it doesnt work, try to reset the CMOS battery.
A common cause for this is a program of some sort that's preventing the shutdown. Luckily, there is a way to force stubborn programs to exit. Read this
http://www.theeldergeek.com/power_down_the_computer_after_shutdown.htm
Well simply insert the OEM (the os install) disc for your laptop and it will do all for you to format. Or you can do this:
1. For this to work you must create a MS-DOS bootable floopy. How to create a MS-DOS bootable floopy:
(In your case, as you do not have a version of Windows on your system, ask a friend if you can use their computer to create one, it does not involve anything that could mess up their computer!)
Making a bootable floopy: (For Windows XP)
1. Boot the computer to Windows, and logon
2. Insert a floopy disk
3. In My Computer, right click the A: Drive.
4. From the drop-down menu, click Format...
5. Enable the checkbox beside Create an MS-DOS startup disk.
6. Click the Start button and follow the screen instructions until the process is complete.
Now, still using your friends computer, you need to copy some files to this bootable floopy.
1. Download Killdisk from here: http://download2.lsoft.net/killdisk.zip
2. When the download is complete, open up the .zip file and copy and paste the following files to the bootable floppy: Copy and paste these files: Copy the Active@ KillDisk for Hard Drives file (KILLDISK.EXE) and DOS-extender file (DOS4GW.EXE) to the bootable floppy disk.
Now its time to start erasing!
WARNING: FOLLOW THESE INSTRUCTIONS CAREFULLY. It does not really matter if you muck up though, because you can just inserting that floppy till you get it right!
1. With the PC power off, insert the Active@ KILLDISK for Hard Drives floppy disk into drive A:.
2. Start the PC by turning on the power. The screen will display the Microsoft DOS prompt.
3. At the DOS prompt, run Active@ KILLDISK for Hard Drives by typing:
KILLDISK.EXE
All system hard drives and floppy drives will be displayed in the left pane along with their system information in the right pane.
Change the position cursor using the keyboard [Down] and [Up] arrow keys.
Information in the right pane will change according to the structure of the detected devices.
4. Hard drive devices are numbered by the system BIOS. A system with a single hard drive will show it as number 80h. Subsequent hard drive devices will be numbered consecutively. For example the second device will be shown as 81h
Be certain that the drive you are pointing to is the one that you want to erase. All data will be permanently erased with no chance for recovery.
5. If there is any doubt about which drive to select, preview the sectors in the device by pressing [Ctrl + S].
Scroll up and down using the keyboard arrow keys, [Page Up], [Page Down], [Home] and [End] navigation keys. Jump to a specific sector using [Ctrl + G]. When you are satisfied with the identification of the device, press [Esc] to exit this screen.
6. When you have selected the device to erase, move the cursor to that device and press [Enter] on the keyboard.
Using the keyboard arrow keys, select the feature that you want to configure. Press [Enter] to make a change.
The Confirm Action screen will then appear.
7. This is the final step before removing data from the selected drive for ever. Once the process has started, you may stop it by pressing the [Esc] key.
Type ERASE-ALL-DATA and press [Enter]. Progress of the erasing procedure will be monitored in the Disk Erasing screen.
7. If you wish to stop the process for any reason after it has begun, press the [Esc] key. Please note, however that erased data will not be recoverable. There is nothing more to do until the end of the disk erasing process. The application will operate on its own without user intervention.
If there are any errors, for example due to bad clusters, they will be reported on the Interactive screen. If such a message appears, it will be possible to cancel the operation (by pressing [Esc]), or continue erasing data.
Thats all folk
You can now install your Operating system simply by insterting the install disc!!
Posted on Jan 10, 2009
    Genius:
  • 3,422 Answers
HI,
Can you please describe your problem so that i can help you fix it.Please let me know know what kinda error code do you get.
  • Dell Master
  • 13,433 Answers
What is the error code? if it happens before the windows starts up, you most likely have corrupt files and the best solution would be to use the windows installation cd to perform a fresh installation of windows to get the computer working normally, after this you are required to isntall the drivers for the computer, unless you have a restore disc that does it automatically.
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
I don't know my computer shuts down automatically.
In order to advance on the resolution path, could you please check the following :
This problem could come from a power saving mode that we see more often these days.
You must ensure that there is any setting in the BIOS that could cause the machine to shutdown ? If you want to make sure it's comes from the BIOS or from the Operating System (I suppose you use Windows), I recommend you to boot a linux live CD on a usb stick or CD. My recommendation would go to download and burn the latest Kubuntu CD, then boot on it (without installing it of course), and wait for 2 hours to check if the computer did stop or not.
Jul 09, 2011 | Computers & Internet
PC is restarting while booting
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly. If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box.
Dec 20, 2010 | Dell Vostro 1510 Laptop
Conputer is shutting down but it does not shut down
Hold the power button until the computer shuts down.
Restart and press F8 key repeatedly until you get a start up menu.
Select safe mode from the menu.
After the computer boots up, and you are at the desktop, go to my computer and select properties of the C drive (your system drive). Select tools from the tabs, then defrag. When defrag finishes, select check drive for errors and select the box, to automatically fix errors, and then ok, and yes at next window, allowing the computer to schedule the error check at next boot.
Reboot and allow computer to scan the drive.
After it finishes, you will continue into windows. Allow windows to boot. After it finishes, attempt to shut down again.
If it works, you fixed it. If not, you have a driver or program that will not quit, and you will have to research further to find out what is running and why it won't quit.
Dec 16, 2010 | Acer Aspire 5735 Notebook
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
I can't shut down my PC,It restarts again!
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 308427 (http://support.microsoft.com/kb/308427/ ) HOW TO: View and manage event logs in Event Viewer in Windows XP To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
    At last if nothing works then clear the "Star up"
  7. C:\Documents and Settings\All Users\Start Menu\Programs\Start up
    If you are not satisfied then If you are using XP then repair it.
thanks
Jul 05, 2010 | Computers & Internet
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
OR
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Computers & Internet
The computer starts then shuts down.
Try booting up the computer pressing whatever key the Dell needs to boot into BIOS (F10, Delete key, F1...pay attention to the screen) and leave the computer on for about 15min. See if it cuts off then. If it does its more than likely your power supply. If it doesn't then its not hardware related.
Mar 12, 2009 | Computers & Internet
Automatic restart
This is may occur due to following reasons:
1.please check BIOS power settings..
2.If boot file got corrupted this issue may occur.
trouble shooting steps:
Open Command prompt in Computer
Start >> Run >> type cmd >> press enter.
Now type chkdsk /f
now type : y
then restart the PC it fixes the boot file errors.
Clarifications required:
Please let me know are you getting any error while restarting computer. While Startup Windows XP does it opening any programs automatically or not?
Feb 18, 2009 | Acer TravelMate 2300 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Dell Dimension 2400 PC Desktop Logo
29 people viewed this question
Alun Cox
