Question about Moose Ch6ac Ch-12a 6 & 12 Volt Power Supply Transformer
I want manual for supply 12 volt - Moose Ch6ac Ch-12a 6 & 12 Volt Power Supply Transformer
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
No power to starter starter is good
Confirm power is availible at starter main power supply, step one , using mutl meter check for 12 volts at battery positive terminal , 2, check main voltage supply lead to starter from battery pos post , 12 volts present? yer check voltage supply lead from battery pos post to altenater , then to starter , 12 volts present, yes , check small wire to starter at starter for switched 12 volts present yes change stater after confirming suitable ground, no, trouble shoot ignition / starter switch in colume
Mar 08, 2013 | 1999 Land Rover Range Rover
30amp auto shutdown fuse blows is it alternater
The ASD relay supplies battery voltage (12+ volts) to the fuel injectors and ignition coil(s). With certain emissions packages it also supplies 12-volts to the oxygen sensor heating elements. The Fuel Pump Relay is a separate relay controlled by the ASD relay input to the PCM. Fuse #12 (10amp) provides 12 volts to the coil side of both the relays and the ignition switch. Fuse #6 (30 amps) supplies 12 volts to the output side of the relay. Fuse #16 (15 amp) from the relay output to the Oxygen Sensors and Fuse #26 (15 amp) relay output to the PCM. Fuse #24 (20 amp) is Fuel pump relay output to fuel pump. Fuse #19 (10 amp) supplies 12 volts direct to the PCM.
look for burned or melted wires in the offending circuit.
sounds like you wiggled a wire while installing new relay.
Mar 06, 2013 | Cars & Trucks
New GA-990AX-UD3 motherboard will not boot
You really should take that Power Supply, and use it on grandma's computer.
The 8-pin EPS +12 Volt power cable was brought out, to provide more power To the motherboard AND processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
The 4-pin ATX +12 Volt power cable has TWO yellow wires.
Yellow wires are 12 Volt wires. (And two Black ground wires)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
In the motherboard manual, does it say, "Yes Tom. Go ahead and use a 4-pin ATX +12 Volt power cable. We don't care. We just use an 8-pin EPS for fun."
[ This is an 8-pin PCI Express power cable. Completely different,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8 ]
The motherboard probably uses 150 Watts by itself.
No Ram Memory, no CPU, no fans, etc.
The CPU could use up to 125 Watts of power. Just depends on what AMD, socket AM3, processor you are using.
Now to graphics card's power;
The most Wattage a PCI-Express x16 slot can deliver is 75 Watts.
The most power a 6-pin PCI Express power cable can deliver is 75 Watts.
8-pin EPS +12 Volt power cable? 150 Watts.
When buying a Power Supply you should calculate all components needing power,
http://extreme.outervision.com/psucalculatorlite.jsp
,then buy a Power Supply that has AT LEAST 10 percent more power than needed. Easier on the Power Supply.
Also a computer will NOT use more power than it needs.
10,000 Watt power supply, (Exaggeration ), and the computer only needs about 100 Watts for surfing the internet?
Computer ONLY uses 100 Watts.
Due to the price, the above, and the availability, you should use a 500 Watt power supply at least.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
http://www.amazon.com/StarTech-6in-Pin-Power-Adapter/dp/B002O21XHQ
Or use it on yours if it has enough Wattage.
Back in the day, the motherboard didn't need to supply that much power to components on it.
More powerful Processors, Ram Memory, and graphics cards, brought the power needed, up.
A 4-pin ATX +12 Volt power cable was added for the motherboard. Then 6-pin PCI Express power cable for graphics cards. Then the 8-pin PCI Express power cable for graphics cards. Lastly the 8-pin EPS +12 Volt power cable.
(Better make sure the Power Supply you have is good, if you wish to use the above power adapter cable. Nothing like having a Power Supply with a weak voltage power rail, and a new build, to pull your hair out on )
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Out of the motherboard manual Page 23,
"With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard. Before connecting the power connector, first make sure the power supply is turned off and all devices are properly installed. The power connector possesses a foolproof design.
Connect the power supply cable to the power connector in the correct orientation. The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start.
To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2012 | Gigabyte Technology GA-990FXA-UD3-...
The power supply came with no manual. There is no P IV power lead. There are two aux power leads. (1) four wire (O,B,R,Y) and (1) six wire lead (B,Y,B,Y,B,Y) The original power supply P IV lead has four...
As you've noted you need two Black wires (Ground), and two Yellow wires (12 Volt),
for a 4-pin ATX +12 Volt power cable,
If you are not using the 6-pin PCI Express power cable,
,rob the 4-pin ATX +12 Volt power cable connector, and wires from the old power supply.
Splice the wires of the 6-pin PCI Express to them.
Note:
Orange wires are 3.3 Volt
Red wires are 5 Volt
Black wires are Ground wires.
You need two Yellow wires, and two Black wires.
Or if you have a spare 4-pin standard Peripheral power cable from the power supply,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
,buy and use an adapter power cable.
Example,
http://www.directron.com/p4atx.html
Nov 27, 2010 | Coolmax Technology COOLMAX M500B 500W EPS...
Which wire is the 'ON-PS' switch for the Astec Model SA145-3435 power supply?
I found out that the AT supply SA145-3435 does not have a switch wire like an ATX supply. I have a SA145-3435 my self. To get it to work it must have a +5 volt load (BLACK and RED) and a +12 volt load (BLACK and YELLOW). If it does not have both of these loads it will power down after a 2 second delay when you plug it up. I used 2 small 12 volt bulbs. One for the 12 volt line and one for the 5 volt line. The type of blub I used was a #94 I got from the auto parts store.
Oct 01, 2009 | Dell 145W Power Supply SA145-3435...
Adding trailerbrakes to a 24 volt truck
Are your electric brakes rated for 12 volt or 24 volt, that is the question. YOu have to supply the voltage at whatever the brakes are rated for.
Apr 15, 2009 | IBM LENOVO 24V POWER SUPPLY 42L0085 Power...
LCD tv issue
at error code is 12 and it is your 12-volt supply. Measure from the inverter to the power supply for 24 volts pins 1,2 and 3. If you don't have the 24 volts disconnect the inverters from the power supply and see if the volts come up. If the 24 volts come up replace the inverters. If the 24 volts are still not there replace the power supply. The volts have to be steady and not going up and down if they are replace the power supply.
But if the 24 volts are there with the inverters connected 1M03 pin 3 for 3.2 volts. If the 3.2 volts are not there replace the small signal board. The only way to get a manual is to find it on line or call the manufacture.
Aug 26, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
I was given a kenwood ts440s hf transceiver and it has the leads for dc power supply. What can I use to power this radio? Is it primarily set up for mobile use or can it also be powered for in house usage?...
To use supply the radio with 12 volts you would have to use a power supply such as an Astron which can be purchased at Ham Radio Outlet and other ham radio shops, you can get their number on the internet. The 110 AC to 12 volt DC is not the problem..it requires the amperage to make the radiois work.... You can use a 12 volt battery and use it for a maybe an hour without charging....the radio will not work with a car battery charger... Hope this helps
Mar 09, 2008 | Audio Players & Recorders
Moose Ch6ac Ch-12a 6 & 12 Volt Power Supply Transformer Logo
42 people viewed this question
Top Moose Home Security Experts
Lawrence Oravetz
Are you a Moose Home Security Expert? Answer questions, earn points and help others
