Question about Ovens
How do i fit a new heating element to a kenwood CK404 oven
The Fan oven has stopped working. Grill still works and light still comes on and fan works but no heat. Have purchased a new heating element for it, but how do I fit it?
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: fan oven wont heat up
    If fan is workintg, but no heat, then replace oven element.
    If no heat or fan, then make sure timer is set on manual and not on auto
    Please rate my solution.
    Thanks.
    Posted on Jul 01, 2009
    • 69 Answers
    SOURCE: my omega europa oven is not heating up .grill fan
    Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
    Posted on Mar 18, 2010
    barkencoa
    • 3463 Answers
    SOURCE: fan and grill works, grill actually cooks but oven
    Without a doubt this is the element that is faulty.
    It is located at the rear of the inner oven compartment behind a removeable cover.
    Posted on Mar 30, 2010
    Kenwood ck405 - main fan assisted oven not heating up - grill working, fan working but think it might be the element - how easy is it to replace element?
    Kenwood Oven not heating? How to replace a Kenwood fan oven element
    This video will show you how to replace fan oven element in your
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Kenwood element How to Repair Home Appliances
    Feb 17, 2010 | Ovens
    My kenwood ck404 rangestyle main oven has stopped getting hot, but the oven grill still works, is there a second eliment and if so how would I access it? Thank you
    my kenwood ck404 duel oven the main oven does not work the light does not come on at all but the other oven works and the light is on
    can you help
    Jan 01, 2010 | Ovens
    Fan in main oven boken
    Sounds as if your oven heating element has failed. You need to fit a new one.
    Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
    Dec 31, 2009 | Zanussi Ovens
    The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
    The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
    Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
    My double oven has stopped working, its only the large fan assisted oven which is producing no heat. The top oven/grill works okay. Is it an element problem ?
    If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
    Thanks.
    Nov 18, 2009 | Whirlpool RBD305PD Electric Double Oven
    C362e fan oven stopped heating up fan still works top oven, grill and hob still work.. Had same problem about a year ago, but suddenly started working again before i could get help.... ???
    If fan is working o/k, then it is more than likely that the oven element is causing the prob, I would fit a new one under the circumstances.
    Thanks.
    Jul 14, 2009 | Ovens
    Fan and grill works but not heating up
    Hi.
    If the fan is working o/k, then you need a new fan oven element fitting.
    Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
    disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
    Plz rate this solution.Thanks
    Dec 24, 2008 | Belling XOU252 Electric Single Oven
    Smeg oven
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
    Oven not heating up but fan and light on
    oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
    Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
    Ovens Logo
    336 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
