Washer mashine Ariston Margherita 2000. Fills drum with water. How can I change water inlet valve please?
  • Washing Mach... Master
  • 15,478 Answers
Looks like you have the right things. All you need to do is order and new valve set and attach it. The problem could be the power or the switch to it though
Posted on Nov 29, 2012
huuum
  • 750 Answers
SOURCE: Our Ariston Margherita 2000 AB95
hello chels_z
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your Ariston Margherita 2000 AB95 Sounds like a jet plane when spinning
And asked me Is it worth fixing?
That depends how old the unit is?
Let me know what the results are.
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Sep 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
ginko
  • 19396 Answers
SOURCE: Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Posted on Apr 18, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
graemevm
  • 519 Answers
SOURCE: I am looking for an user guide/instruction manual
I'm not sure if this is the exact model but it is for an Ariston Margherita 109. Here is the link to download the manual:
http://laundry.manualsonline.com/regman/exit/ct?url=aHR0cDovL2ZpbGVzLm5ha3Vwa2EuY3ovZWxla3Ryby9lYi0wNjQyMi5wZGY,&target=productDoc&idDeviceType=3004&idMfg=5539&idProduct=269002
Click on the above link or copy and paste the link to your browser address bar.
Note that the manual is in PDF format and will require Adobe reader to open it. If you don't already have Adobe reader you can download it for free from www.adobe.com
Best wishes,
Graemevm
Posted on Mar 08, 2010
The machine works OK but when finished, with the two water valves left on, the drum fills with the machine turned off
Replace your water inlet valves in washer they are seeping water.... If I helped please vote need more help please ask.....Good luck
Feb 07, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
Fills with water when not in use.
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
