Question about Maytag Kitchen Ranges
My stovetop and controls are working fine but, my oven isn't heating up is it the plugin?
I bought this stove around ten yrs ago brand new. My wife was cooking when the bottom element arced in two, I replaced it with a new element and now it heats very slowly. I think that the top element is working, but it might not be very hot. The bottom one that I put in doesn't even get hot at all you can touch it with your finger after preheat @350 for15-20 mins (which it never reaches 350` not even 200`)
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
aborcass
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
aborcass
  • 2651 Answers
SOURCE: oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Posted on Mar 26, 2008
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven
Yes, that sounds like a relay on the oven control board. Here is the part to order that has a 365 day, any part, any reason return policy so you may want to order from them.
Jun 25, 2013 | Ovens
THE STOVETOP ON MY KENMORE ELITE IS SO HARD TO CLEAN. BOUGHT THE STOVETOP CLEANER AND I STILL CAN'T CLEAN IT UP.
Try using some oven cleaner on the stove top. It will break up the cooked on gunk.
Dec 22, 2012 | Kitchen Ranges
Brand new oven, maytag, the oven won't heat up and
IF IT IS STILL UNDER WARRENTY DON"T TOUCH IT CALL THEM BACK , MAYTAG HAS MANY PROBLEMS BUT THEY ARE GOOD AT REPLACING UNITSTHATHAVE PROBLEMS , PLEASE LET ME KNOE WHAT HAPPENS IF YOU NEED ME TO CALL THEM GIVE ME THE INFO AND I WILL DO THIS BUT SHOULD BE OK
Dec 01, 2011 | Maytag Ovens
Oven will not come on
There is a oven controller on those type ovens and if you cannot get your oven to heat up but the stove top still works it is because there are on different circuits and the cotroller will cost near $350 if you have a convection oven and twice that for a service person to install!!
Sep 11, 2009 | Frigidaire FEF366 Electric Kitchen Range
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Kitchen Ranges Logo
119 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
