Question about Garden
Catalina Hot Tub not working and Sn1 showing on panel
Nothing will work as sensor has shut down everything
2 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
2002 mercury mountaineer just dies while driving it has a brand new battery everything works but doesn't make a noise while turning ignition key
Have you tested for a failed starter or it's solenoid ,
after it stops & you have nothing ?
Could be your loosing throttle position, if a sensor or
ignition coil is bad,that will shut it down
Check for OBD Codes
Oct 28, 2014 | 2002 Mercury Mountaineer
My furnace draft inducer starts up and the sequence starts. then the pilot comes on and then it ignites the burner, then it will start the burners. Then about 2 minutes later the burner goes out. And
There is a pressure switch that checks to see if the blower is working at full power and if it detects it is not it will shut everything down. Find a little pressure sensor coming off the blower assembly at the end of a little rubber hose. Take the hose off and suck on the sensor nipple and see if you here a click noise, if you don\'t the sensor is probably shot and needs to be replaced. You can find them cheap on ebay. I can\'t remember exactly what they are called something like blower pressure sensor but if it does not work the whole thing shuts down shortly after start-up to protect the furnace.
Apr 07, 2013 | Heating & Cooling
The car cranks but won't start. There is no spark, no fuel, no injector pulse. I have manually made the contacts in the shut down relay still nothing. I jumped the fuel relay and the fuel pump runs and I...
If you remove the fuel line and crank the engine and get fuel then you could be assured that the crank sensor works but if there is no fuel while cranking then the crank sensor is most likely the fault. If the crank sensor is not the problem then it is most likely in the coil or distributor which the 97 is notorious for.
Sep 06, 2010 | 1997 Chrysler Cirrus
Nothing works,door locks, lights, no noise of any
security system failure will shut everything down
(IT THINKS IT IS BEENING STOLEN) an locked it self out
Mar 03, 2010 | 2005 Chevrolet Equinox
Mine does the same thing...
If the main light is flashing 10 times you have a door sensor problem. Might be the wiring to the sensors. Nothing else will cause this flashing of the main light.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Shutting Down
hsve the crankshaft sensor checked
Sep 04, 2008 | 2000 Buick LeSabre
The power cord is hot but no lights or clock, nothing works.
ok " un plug coffee pot, if you take the base apart you will find the wiring, follow wiring to a round disk on the heating tube ,
that disk is a heat sensor , replace that sensor .
any appliance parts store will have them
sensor is bi-metal on the inside when it gets too hot it shuts power down.
Jan 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
