Question about Olympus FE47 Digital Camera
Olympus fe47 camera has lines across picture like a Venetian Blind
Looking through viewfinder is clear as normal, after picture is taken there are lines across the whole picture, best described like looking through a partly open Venetion Blind. This occurred after taking a picture of the sun, during sunrise, now every picture taken has these lines across them, and I cannot clear them. The fe47 is now useless.
advance
  • 107 Answers
SOURCE: broken camera
It is likely that your lens assembly was knocked out of alignment when you dropped the camera. When things do not line up inside the lens the whole unit cannot move in and out. This malfunction requires disassembly to fix, so you will have to get it to a professional for repair. There are providers online who can repair your camera, and also check with your manufacturer to see if they can service the camera at a reasonable rate. David Millier Advance Camera Repair
Posted on Mar 06, 2007
  • 3 Answers
SOURCE: BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
Posted on Feb 16, 2008
nikonian2
  • 154 Answers
SOURCE: Lines on pictures
in what setting did you take this picture ? try a camera reset (it is in the setup ) if that doesn't work try the internal memmory first, than a Xd card
are the pictures it takes only so on the camera or also on the pc ?
Posted on Apr 22, 2008
  • 1894 Answers
SOURCE: pictures look like view through a venetian blind
i think the grid lines have been enabled.
and so disable it to having the problem solved
Posted on Jun 16, 2008
fotobean
  • 103 Answers
SOURCE: Olympus E300
Hello Kate, See if you can find an internet cafe. I was reading the white balance section of your manual and there is nothing that stops your camera from taking pictures if the white balance is off. Turn your camera off, remove your batteries for about 30 seconds and let it reset to default. Then try inserting the batteries and see if this helps. I wouldn't mind sending you this manual if you can provide an email address. Or a link to go to is: www.olympus.com, then select americas, then select support, then select your camera, then download your manual in PDF format. I wouldn't want your vacation ruined either.
Posted on Jan 06, 2009
Photo taken some lines
is either camera firmware problem or something more serious with the camera.
Jan 27, 2013 | Olympus FE47 Digital Camera
I have a Olympus C-750 UltraZoom. I was taking pictures and everything was normal, but then I noticed the viewfinder was blurry. I was walking through a tunnel under a river and I thought the temperature...
Hi Steve, I inform you that the problem only is moisture. Please follow this.
1. Put the camera in sunlight for few hours. After that use it & if you face same problem then
2. You need to visit camera repair shop and they open the camera completely and clean all the inside part of the camera. because you need to clean the moisture inside of lens, viewfinder & sensor too.
So only hope in sunlight. If its solve then fine.
Jan 21, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
Pictures are pink with lines
The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
Jul 02, 2009 | Kodak EasyShare M853 Digital Camera
Pictures look like view through a venetian blind
Apr 29, 2008 | Olympus SP-350 Digital Camera
Casio Exilim EX-Z60
You may have a problem with either a loose connection at your circuit board or lens unit.
Mar 28, 2008 | Casio Exilim EX-Z57 Digital Camera
Picture on viewfinder
i have no solution just a problem of my own i need soft ware to use my ge a830 to my pc thank you richard.
Feb 03, 2008 | GE A830 Digital Camera
Help... white lines
I also have the same problem! I absolutely love this camera but suddenly out of the blue I have stripy lines on the screen that look like you are looking through a venetian blind. I have contacted Fuji but they say it will cost £99 to repair or have offered £50 discount on any other camera. I just want my F460 working ok. Please, please can anyone help us?
Nov 12, 2007 | Fuji FinePix F460 Digital Camera
White pictures and lines across pictures
Try this to isolate the problem.
Switch on the camera in auto and put it into full optical zoom. Now turn the camera to face you and angle it so that you can see into the lens without reflection. On full zoom the internal lens will be right up to the outer lens. Now press the button to take a picture. You should be able to see the shutter cover the inside lens and then open again. Did it completely cover the lens? It should do. If not then you will get an over exposed picture or a picture with lines across it.
Email me for more info and how to solve. daveward712@aol.com
Jan 29, 2007 | Fuji FinePix E900 Zoom Digital Camera
Olympus FE47 Digital Camera Logo
35 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
