Question about Car Audio & Video
Hi I have a calibre 4in1 tachometer that I bought
Hi I have a calibre 4in1 tachometer that I bought from supercheap I got it with out any instruction manual so I don't no what wires are what and I want to put it in my 03 hilux 3ltr turbo diesel the colour of the wires for the tachometer are orange,green,blue, yellow, red, black
3 Suggested Answers
SOURCE: I am looking for the wiring 97 fiesta stereo
Ford Auto WIring Diagrams, Image results for 97 Ford Fiesta Wiring Diagrams
Posted on Jan 23, 2010
diodeic
  • 1622 Answers
SOURCE: those are the colour wires that i have in my
Look at your vehicle. Many modern vehicles are being equipped with premium audio systems that are not easily replaced, if your radio or door panel has a logo on it (BOSE, JBL, Harmon, Infinity), you probably have a premium audio system. If your vehicle has a factory "premium" audio system, stop now and go pay a qualified professional to replace it.
2Buy a radio. Be sure that you purchase a radio that will fit in your car (some retailers tell you on the website if a deck will fit).
3Buy a wiring harness and a radio mounting kit. Buy the antenna adaptor. GM vehicles, some European vehicles, and older Nissans (pre-95-96) require an antenna adapter.
Installing Your New Radio
1Make sure you purchased all the install parts that are necessary (dash kit, vehicle wiring harness, antenna adapter).
2Make sure you have all the tools necessary to remove the factory radio, with most vehicles you will only need some screw drivers and a small metric socket set, but some Fords, and most European vehicles need special tools to remove the radio. You can purchase the Ford or VW tools from most good auto supply stores.
3Open up your dash kit and read the instructions. If you bought a quality kit it should have instructions on how to remove the factory radio.
4Disconnect the negative battery terminal.
5Remove the factory radio following the instructions provided with the mounting kit. Remember these dash pieces are EXPENSIVE to replace so be careful not to scratch or break them when you're removing the radio.
6Now that the factory radio is out double check that the vehicle wiring harness you were sold fits the factory radio plug. If it does you can begin to wire up your harness. The harness that came with your new radio and the vehicle adapter harness that you bought should have the same standard colors. Just connect them color to color--- red to red, black to black, Orange/white to Orange/white, and so on.
Here is the breakdown of what wire does what:
+Red..............12v ignition
+Yellow...........12v battery
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
1Install the radio mounting sleeve (cage) into the dash kit by sliding it into place and then bending the tabs until it is securely held in place. Slide the radio into its mounting sleeve (cage) until it locks into place.
2Plug the harness you wired into the vehicle radio plug and plug your factory antenna into the antenna adapter (if required).
3Mount your radio and dash kit into the factory radio location using the factory radio mounting screws (be sure to plug the harness and antenna into the radio), and re-install all the factory dash panels that you removed when taking out the factory radio.
4Your dash should now look exactly like it did before you started except for your brand new radio and dash kit in place of your older radio.
5Reconnect your car's negative battery terminal, and power up your modern electronic marvel.
Hope this will help in solving the problem...
Posted on Aug 18, 2011
1998 Suzuki 1400 Intruder need wiring diagram for tachometer
Hi, Kenneth for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1998 Suzuki 1400 Intruder need wiring diagram for tachometer Google Search
Suzuki Motorcycle Wiring Diagrams
Suzuki Intruder VS1400 Service Manual
OEM parts for Suzuki
Suzuki VS1400 Owner Manual
Apr 18, 2017 | 1996 Suzuki VS 1400 Intruder
Where to connect green tacho wire on holden rodeo ra 2005 model
The green wire is always a ground you must ground it
Sep 22, 2017 | Cars & Trucks
Assuming red is positive, black is negative or neutral the green is usually an earth wire and should be mounted to the cars frame.
Jul 08, 2013 | Cars & Trucks
I have a new Phaff Coverlock 4.0 Serger that I cannot get the box to come up on the screen to calibrate it. There is on stitch in there that coms up, but I cannot calibrate it to make the other stit
I would suggest taking the machine back to the one you bought it from & see if they have another one that will calibrate ,,& if they don't have one ,, I suggest another sewing machine dealer..
or you can try contacting Phaff customer support by phone or email & see what they say
Jan 30, 2012 | PfaFF Sewing Machines
I have a 2003 spyder eclipse gts 3.0l how do i install a after market tachometer?
I really cannot tell you how to do that. You need to follow the instructions that came with the tachometer.
Please note: I would be very cautious about connecting aftermarket equipment into your computer input or output circuits. These things have been known to cause all kinds of drivability problems as well as make it impossible to pass an emissions test (if it is required where you live).
I have personally seen aftermarket add-on equipment cause everything from engine cylinder misfires to transmission shifting problems to engine stalling and no-starts. I do not recommend using any at all. However, there are usually no problems created by "stand alone" accessories that are powered directly from the battery and do not require splicing into any of the computer circuits.
My professional recommendation on this is that if you think you need a tachometer to operate your vehicle, or you just like the looks of a tachometer bouncing up and down, then you would be money and headaches ahead to buy a vehicle that is equipped with a tachometer from the manufacturer - you may be opening a can of worms that you do not want.
This is just my opinion based on 37 years of experience diagnosing and repairing automobiles (and having to clean-up aftermarket add-on messes) - do with it as you wish.
Nov 10, 2011 | 2003 Mitsubishi Eclipse Spyder
I need an Android 2.2 instruction manual, for a tablet I just bought (without useful instructions). Can you tell me where I can download one from? The Droid site download seems not to be...
Hi! I hope this is the manual you were looking for! Android is fairly intuitive, don't worry about messing anything up - you can't really, just browse around and learn. The guide isn't actually tablet-specific, because you haven't told me which tablet you have, usually the specific manuals are only on the manufacturer's site.
Jul 05, 2011 | Computers & Internet
Kd-sx940 manual/instructions for wiring?My original radio was stolen from my 1998 Ford Ranger and they cut the wires,I bought this one but it has the wiring harness to a Subaru,I don't care if I have...
installation manual:
http://books.jvc.com/Download/18989249/FSNU3070-T632.pdf
And, for what's it's worth, the instruction manual:
http://resources.jvc.com/Resources/00/00/99/FSUN3070-632.pdf
May 22, 2011 | JVC KD-SX940 CD Player
Need instructions for the Chicco 4in1 Lullaby Lx Playard
here's a link to the website where you can download the manual for free: MANUAL
Jan 14, 2011 | Chicco 4in1 Lullaby Lx Playard Hazelwood...
1988 Honda GL 1500 Gold Wing tachometer not working
Hi, Dcunni7721 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tachometer not working GL1500 Information Questions goldwingdocs com
GL1500 tach not working
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1500 SE Owner Manual
Sep 28, 2010 | 1988 Honda GL 1500 Gold Wing
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
