Question about Delta 28 276 14" Band Saw W/ 3/4 Hp Motor & Open Stand
Riser block What size wrench do I need to put in riser block?
    Sergeant:
  • 468 Answers
6in riser block for Delta 28-276 14in bandsaw ..
www.bandsawblog.com
Posted on Nov 29, 2012
I have a 2004 yamaha majesty 400 and my knees hit the handles when turning ? i would like to slide further back on the saddle but as you may but not possible. maybe someone out there has an idea
The only thing I could think of without hacking the seating area up is to, put some taller risers on your handle bars to raise them or buy a set of mini ape hangers. Mind you, if you go too Tall with the bars or real tall risers you may need to buy all new (Longer) cables for your controls. If it were me, I'd buy a bigger bike to fit my size and frame.
Jun 08, 2017 | Yamaha Motorcycles
Howdoi remove the oil filter on a 1989 celebrity?
If I recall, that is a rather small filter. There would be a filter remover that fits over the end of the filter and is turned with a ratchet wrench. They are called oil filter cap wrench, at any parts store. There are about 3 different sizes of oil filters, so you need to find the proper fit for your filter.
You put the cap over the end of the filter and use a 3/8 drive ratchet wrench to turn the filter counter clockwise to remove. Once off, wipe the filter surface clean with a rag. then put fresh oil on the new filter's rubber gasket and install only hand tight-as tight as you can get your hands to turn the filter. OR, you spin new filter on till the rubber gasket touches the base of the engine block. then turn filter 3/4 turn more.
Oct 23, 2016 | 1989 Chevrolet Celebrity
Need to replace riser tube in 24 cup coffee urn
You can take yours apart find out the size and buy it at a local hardware store for about 50 cents
Aug 03, 2015 | Coffee Makers & Espresso Machines
Change oil filter
Just the filter: You need a filter wrench that fits your size oil filter. There are 3 or 4 different sizes, so buy the wrench when you buy the new filter to get the right size. Unscrew the old filter. Use the wrench just to loosen it and then you can use your hand to run it off. Have a drain pan to catch the inevitable drips and spills, and to lay the old filter in.` Use a rag and clean the block where the filter's rubber gasket mates to the block. Make sure the old filter's gasket came off with the old filter and is not still on the engine. Where the filter goes on you should see only clean shiny metal.
Before you start the new filter on, it is very important to put clean oil on the rubber gasket on the filter's base. Just dip your finger in oil and run it all around the rubber gasket-if you don't do this it will surely leak there. Now start the filter onto the threaded stud -the mounting stud for the filter-and turn it on down until the rubber gasket is touching the shiny metal base ring on the engine block. Now with only your hands, and not the fil;ter wrench, you need to turn the filter another 3/4 of a turn so it will seal tightly. If you get it half a turn and it gets tight, just squeeze a little harder=get as close to 3/4 of a turn as you can.
You are done. Pat yourself (wipe your hands clean first.). When oil is put in and car is started, check for leaks at the filter.
Good luck.
Jun 17, 2012 | 1999 Dodge Dakota
What size apes can I put on w-out replacing cables
You're going to run into problems other than just the cables. All handlebar wiring is going to be too short and the front brake line as well. You can usually come up about three inches at the most from standard risers to tall risers, 3 1/2" to 4" risers. One other thing that you must keep in mind when changing H-bars, not only the height but the width as well. If you're going to change H-bars, plan on lengthening all wiring and replacing cables and the brake hose.
Good Luck
Steve
Oct 08, 2010 | Harley Davidson FLHT Electra Glide...
1988 Dodge Dakota brake line size question
they should be 3/16" but if you want to be sure, take a quarter inch wrench and put the open end over the line if it is sloppy on the line it is 3/16" , if it fits nicely, it is 1/4" . that is the only two sizes they could of used.
Jun 06, 2010 | 1988 Dodge Dakota
How do you get the pivot nut off the handlebars?
Hi!!
For this you need another set of wrench which looks like a crab claw.. stop using the wrench thats only for the top nut...
Use Rail Barrel Nut wrench...
Regards
Berry
Jan 30, 2010 | Yamaha FJR 1300 A Motorcycles
Window in my solora went down now it wont go up no response frome motor or any thing is there a fuse or do i have to buy a new motor kit for the window is there an instruction manuel i can get on how to...
the window riser motor is fried or u can try replacing the carbon brush but its too much work... just buy a new riser motor and replace it, u need a knife or similar tool to remove the door panel.. dont damage the plastic lock... ur gonna need it when your done replacing the riser.
youre going to need socket wrench to remove the riser bracket... usually 10mm. socket'll do removing is easy... just try to remember the sequence of your removal... then when your done replacing the motor, install the components you removed in reverse.... Qoute "first in last out" reverse engineering motto....
Jul 19, 2009 | 2001 Toyota Camry Solara
Oil change specs
the engine takes 4qts w/filter and the drain plug is 17mm.
Apr 12, 2009 | 2001 Hyundai Elantra
What wrench do I need to remove front calipers on a 2002 Focus?
A set of wrenches and either a c-clamp or vise grips that look like the c-clamp, and a small block of wood. You'll have to push the brake calliper piston back in.
Apr 05, 2009 | 2002 Ford SVT Focus
Delta 28 276 14" Band Saw W/ 3/4 Hp Motor & Open Stand Logo
99 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
