Question about Acer S220HQL Monitor
Monitor DVI does not work
DVI port stopped working.but VGA still works. The computer works Ok with another monitor with DVI port.
4 Suggested Answers
SOURCE: Acer AL2002W Monitor
For DVI you need to probably upgrade your cheap graphics card, something not that expensive would be a ATI Radeon HD2400 Pro, it'll do. May want to check what pwer supply maybe required on your PC.
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
budmrtn
  • 11361 Answers
You may have problem in the logic board, it uses surface monted components no much chance for DIY repair.
Service manual; http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2216W&kategoria=monitor&kat2=all
The cases these days are hard to open, they use plastic finger hooks types, they go in easy but real hard to remove without damageing them.
Use thin flat blade to crack open at the bottom edge so the scratches will not be so noticeable, and work your way around, look out for cables attached to the front bezel also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 31, 2011
What connections are required
Make sure the monitor works on a friend's PC using the DVI... let's not go backward to VGA when DVI is available on both the PC and monitor. If the monitor works, install the driver and reboot. It should work for you too.
Jun 19, 2014 | Gateway HD1900 19" Monitor
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
When dvi plug is used screen gets funny bright colored lines
FIX for design fault of ASUS VW222u Problems with monitor using dvi while vga works fine.
my ASUS VW222u had the same problem many are reporting after about 8 months
with developing colored "noise" onscreen or dancing red pixels while using dvi but vga is fine.
luckily my old man is an electronics engineer, rather than be without a monitor since vga still works fine we decided to have a look.
we worked out the problem. note: this is a fix for the random picture noise problem while using dvi port.
If monitor works ok with vga but dvi has noise then this fix should work for you.
1.open monitor (will void warrenty)
2.unplug all the the cables going to the power supply and dvi port assembly, undo two screws pull down and out you wil now be looking behind the dvi port and be holding a metal module that contails power supply and dvi- and vga port.
3.you will notice a piece of brass foil joining the earths on your dvi and vga cable this is the problem creating an "earth loop" as both vga and dvi ports are earthed to the metal casing this extra earth is causing the problem introducing noise.
3.carefully unwrap the brass foil from the two cables and seperate, insualte cables with electrical tape. (wrap around each one seperately they should now be indiivdual cables)
4.you will notice a silver spring type peice of metal on the assembly that pushes against the
main body of the unit when re-assembled. scratch the metal with a screwdriver where this peice pushes so you get a good connection when you reassemble it, do not touch as finger grease could screw up the connection. (this step is not vital just a good thing to do why your in there to make sure the the unit is properly earthed)
4.re-assemble
enjoy, fixed mine and was quite easy, take care with the plastic latches they are tight - ensure you remove all 5 screws, to see the fifth easily the monitor stand must be removed (two screws then stand slides out from rear of case)
good luck
bcmalloy
Apr 25, 2009 | ASUS VW222U Monitor
Is this monitor compatible with any desktop computer?
Your monitor will work with any computer.
Note, if your monitor only has a DVI cable, then you will need a VGA to DVI adapter if the new computer only has a DVI port but most new computers will have VGA.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 15, 2009 | AOpen 19" LCD
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Acer S220HQL Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
