Question about Samsung SCX 4200 All-In-One Laser Printer
I have a samsung scx 4200 the glass cracked and needed to be replaced, now the scanning mechanism keeps wanting to go in just one direction, so when it reaches the very left the cogs continue tuning and I have to put the whole thing off to stop it, is there some sort of reboot that needs to be done or something?
  • e_mari
    e_mari Dec 19, 2012
    I have the same problem with my SCX 4500. Powering up the printer on the scanner motor does not stop and continues to bang on the limit. Then it gives me the generic error (triangle). It seems that you have not calibrated synchronization. How to intervene?
  • e_mari
    e_mari Dec 19, 2012
    Master:
  • Samsung Master
  • 551 Answers
Dear
The scanner glass may restrict the movement of the CIS. try to clean the foreign particle from its gear assy. Its also the scanner cable fault replace with anew one.
Thanks.
Posted on Mar 04, 2015
3 Suggested Answers
SOURCE: How do you scan with Samsung SCX-4725fn?
Having encountered this issue, I read the manual. The only way I found it to work was to press scan and then choose the application that you want to use. I normally just choose scan to Paint. Then launch Paint on your pc, Go to File and select From Scanner and Camera and your image will appear in Paint. (not the easiest scan method in the world but it works; I have tried selecting the other applications on the scanner menu but haven't had any success.
Posted on Feb 18, 2010
SOURCE: samsung scx-4200 refilling second time
CAN I RESET MY SAMSUNG SCX4200 TONER CHIP MANUALLY BY SOLDERING
Posted on May 03, 2010
How to scan into my computer
Hello, I am happy to help you with your question. Samsung SCX-4200 supplies software calls Samsung Smarthru. This software application includes a scan command. The software is locagted on the CD that accompanied the printer.
Here are some excerpts from the manual:
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
Dec 22, 2010 | Samsung SCX 4200 All-In-One Laser Printer
I lost the cd for the software How can I get the scanning software? i am using Samusng SCX 4200
check this site and download only for scanning driver, http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SCX-4200
Apr 06, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Simply don't know how to begin using the scan function on the SCX Samsung multi-functioned printer.
First of all, you have to install the drivers, that can be done by installing the applications that came with the CD that came with the printer
Then when you have installed these drivers, restart your computer.
Simply now, put the paper you want to scan in the scanner, and press the scan button.
Jun 01, 2009 | Samsung SCX 4200 All-In-One Laser Printer
How to operate the scanner on samsung scx - 4200 model printer. how to scan using this printer.
a scan button will be there on the printer check it out press it to scan the desired paper
or else u can scan from the solution centre ..........goto start -programs--samsung printer--in that choose scanner
Nov 22, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Noise during scanning
Not really these are sealed units - nothing to repair. If it works grit your teeth and bear it. If you open it up and try to lubricate the offending parts the chances are you will kill it dead.
Sep 19, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
76 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
