I have problem with the ricoh mp 2352 showing sc 142 but some time you can make few copies and this machine has done only 1254 copies
  • 287 Answers
It is rather odd fo you to get this code for such a new machine. It means that when it starts up it turns on the scan lamp and shines on a "white plate" and uses it as the benchmark and calibration for what "white is". What it sees when it checks white is beyond its abilty to compensate. Dirty optics maybe.
Posted on Dec 03, 2012
  • 86 Answers
SOURCE: Functional Problem on our Ricoh 1018D
Enter SP mode - Clear (yellow) key, 1 0 7 and hold and press stop (orange) key for 3 seconds.
Enter SP 5-810 (SC code reset) and
select “1”. Then switch off and on the machine.
If error still there, probably you have one of the following faulty;
Fusing thermostat open,
Fusing thermistor open or defective,
Fusing lamp open or
Power supply board defective.
Please, first check fusing lamp and thermostat for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: Ricoh Aficio 1232 c SC-101 and SC-142 codes what do they mean?
It is a scanner problem....could be lamp, lens defect, or as simple as the lamp, and lirrors undeer the glass being very dirty, because the code refers to the 'white level"....a calibration that the machine does when switched on. It could be as simple as, the white plate which is underneath the left scale (beside the main contact glass) is dirty (or missing). Try cleaning this (2 screws), and while you're at it, try removing the main contact glass (3 more screws)and cleaning it as well as the scanner bulb, and mirrors (slide scanner to the right with the machine unplugged).
Good Luck
Posted on Mar 02, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Ricoh Aficio MP 4000 sc 870 error after power cord
SC870 = Address Book Data Error. This is most likely a hard drive failure especially considering the power loss. This is about a $175 repair in case you want to call around locally and get estimates to replace the drive. There is an outside chance you can get someone to walk you thru the Service Mode and do the following to reload the address book:
1. Enter the SP mode
2. 5846-50 (Initialize All Address Book)
3. Turn the machine off then on again.
Good Luck
Posted on Oct 20, 2009
  • 393 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
SOURCE: Sir, My copier model RICOH MP
My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 101
Posted on Nov 18, 2010
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
Mar 16, 2015 | Ricoh Savin Lanier Genuine Toner Type Mp...
Mp 2000 sc 982
i'm guessing == Scan, Color
Jan 03, 2015 | Ricoh Aficio Mp 2000 Copy Machine
Error 365 what the solution of it
SC-365 Image storage error VI out of specs, drum, drum potential sensor, charge corona, dirty optics FT 7950, 7960, 7970
Nov 24, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
What is the solution to this problem aficio mp c2501 sc 532
The fuser not set right, check the connector in machine that the fuser connects into. If it is broken, the harness with that connector needs replacing. The SC532, replace the ventilation fan (at the left side of the machine) motor-front or rear.
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
How to FIx Code SC 561
Defective thermopile. If replacing the fuser does not help it will need to be replaced.
Aug 10, 2014 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
135 people viewed this question
k24674
