Changing 7 wire ballast to 6 wire ballast
I have 7 wire ballast for 2 x36w lamps new ballast has 6 wire
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its got to be the wrong one--wrong ballast.
Posted on Dec 22, 2012
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Posted on May 12, 2008
  • 230 Answers
SOURCE: ballast on samsung hlp4663w
The transformer can't damage the new lamp. Faulty transformers normaly take out the driving transistors or the fusible link in the power supply, if these are good then just replace the lamp. Espacially if you know the lamp is bad (test it by swapping with the others if unsure)
Posted on May 25, 2009
jdvillanueva
  • 2098 Answers
SOURCE: yrf@bellsouth.netthe connector from the ballast
Hi murrayrf,
Please click this LINK to order online for the parts you are looking for.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 11, 2011
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
When installing new lamp, should ballast be replcaed also?
Is there any noise coming from the cable box? My TV had similar problems, and when I had Comcast change the faulty box, the problem stoped
Jul 02, 2014 | Mitsubishi WD-62327 62" Rear Projection...
Np2250 lamp will not shine
The wires that go from the bulb socket to the circuit board is the ballast. This board controls the lamp operation. It is most likely the source of your problem.
Jan 13, 2014 | NEC Brand NEC Replacement Lamp For NP1150...
Changing ballast
do not even try that.
Nov 29, 2012 | Televison & Video
I have an ge proline magnetic t12 ballast it has two red leads two blue leads and two yellow where as my fixture has one red one blue and the hot and nuetral are wired through the other side of the bulb...
Need more information, how many lamps are in the fixture? The new ballast is for how many lamps? Basically you need to follow the diagram on the new ballast. If the new ballast is for a four lamp fixture one yellow gets capped and the other yellow goes to one side of each lamp on a two lamp fixture. Then on the other side one set either red or blue goes to the other side of the lamp one wire per lamp and the other set gets capped . Hopefully this helps parkeroc68_0.jpgparkeroc68.jpg
May 22, 2011 | Electrical Supplies
I have a 4 ft 2 lamp flourescent system. I am changing the ballast. The existing wiring has blue / red / yellow / black & white wires. I have a new ballast (yes I confirmed at the store it is the...
The first thiing I suggest is checking the installation instructions (either included with the ballast or on-line) of the ballast you just purchased. Many fluorescent ballasts require that the lamps be wired in series - which I believe is what you had before. One lamp connects between the red & the yellow, the other connects between the yellow & the blue. Other fluorescent ballasts require that the lamps be wired in parallel - which may be what you have now (both lamps connect between the red & the blue). The installation instruction sheets should designate the appropriate wiring configuration.
That being said, just double-check one thing: Make sure the new ballast is rated for 2-lamps. Ballasts rated for 1-lamp will only include the red & the blue (no yellow). So I know you sad you already checked with the destributor, but double-check that one point.
May 15, 2011 | Electrical Supplies
No power to lighting ballast ,only lights up on loss of power 277v at emergency ballast
Follow the appropriate wiring exactly. There are about 6-8 different diagrams. Find your lamp type and number of lamps. Locate your ballast type (usually instant these days) Quite often these diagrams show a switch on the power lead going to the operating ballast. If it isn't on a switch be sure to wire it in with the lead to the emergency battery ballast.
Jun 30, 2010 | Lithonia Lighting Psq500 Power Sentry...
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
How to replace a tube holder or ballast
You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
