PANNEX floor heat. A zone light is off, while all other lights are red. Pressing the OK button will turn this light red and all the other green. In this zone there is no heat in the floor. What is the problem?
SOURCE: New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Posted on Sep 05, 2008
  • 85 Answers
SOURCE: Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Posted on Mar 13, 2009
indus3
  • 212 Answers
SOURCE: red light is on
verify if the paper guides in the paper trays are set exactly to fit the paper edges, since the printer defines the paper size with these paper guides. then verifiy if the paper settings in the printer driver are set to the exact same paper size as the paper used in the paper tray.
Posted on Oct 12, 2009
komguy
  • 2306 Answers
SOURCE: I am attempting to instal a Canon iP4700. Step 3 in
First try taking the inks out and the printhead and see if power stays on. If so you need a new printhead. the part number is on the side. If not, sounds like a bad power supply.
Posted on Nov 06, 2009
SOURCE: both green and red light flashing unable to get
How to reset counter on my Epson C-62 Printer I cleaned the Pads
Posted on Oct 30, 2010
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Green light is blinking --says clean when you push
    Hello & Welcome to FixYa
    Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
    High temp wash-heated dry-high temp wash-heated dry
    Please get back to me if you have any other questions.
    Kevin
    Jun 10, 2011 | Kenmore 16764 Dishwasher
    Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
    hi
    You can reset the lamb timer as follows.
    While pressing the MODE button, press the POWER button three times.
    all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
    ok
    Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
    Sunbeam heating pad no longer heats. The red
    I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
    Jan 12, 2010 | Kitchen Appliances - Others
    The Zone 1 (basement) and Zone 3 (second floor; no
    On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
    Dec 26, 2009 | Honeywell Electronic Programmable...
    Turns off after 4 secs or so....From Green to Red,
    Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
    Aug 25, 2008 | Denon AVR-1905 Receiver
    Water filter warning light
    Push the light - it will flash red after a few seconds -then turn green.
    The answer above on this page was correct
    Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
    23 people viewed this question
    k24674
    jasbo
    jasbo
