Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Won't agitate the tub fills but it won't agitate or allow water to drain. now i have a washer filled with water and no repair man until thursday, help!
  • 5 more comments
  • ljhjbrown Jan 10, 2009
    where does one purchase a lid switch?
    just spoke with someone thinking it may be 'cuppler' on motor, what do u think?
    looks at me supid
    thanx u rock
  • rmgjag1 Jan 10, 2009
    Not sure if this is the same problem but I have the same machine. It filled with water then stopped, no response from the cycle dial in any position lid up or down. Any suggestions?
  • ljhjbrown Jan 14, 2009
    bill...you were correct, repairman fixed it, thanx again
  • dmace01 Jan 14, 2009
    I discovered that the lid timer has burnt contacts as well as with the black piece through which the 3 wires connect with the lid timer. I have purchased a new lid timer and am wondering if i can find the black peice of plastic which holds the 3 wires and connects to the lid timer.
    Sergeant:
    Champion:
  • 262 Answers
The lid switch is bad but a new one and replace it and you will be washing again
Posted on Jan 10, 2009
  • 4 more comments
  • Bill Dozier Jan 10, 2009
    YOU NEED YOUR MODEL NUMBER YOU CAN GET IT AT APPLIANCEPARSTPRO.COM oh sorry about the caps. or you can purchace at a appliance parts store /supply house
    could be does it make any noise when it goes to agitate of just looks at ya stupid?
    ok then it is the lid switch if you have no noises at all.if it would of made a racket then motor coupler had broke without being there I
    'd put my money on lid switch let me know.....bill
  • Bill Dozier Jan 11, 2009
    Thanks I try my best to help
    rmgjag it too sounds like you have got a faulty switch pull the consol loose and tilt it back you will then see a plug with three wires on it remove the top part and bypass the inner and outter wire with a peice of wire stripped on boyh ends just stick it in the holes blue and green wire gray is the center if it works that way replace the switch
  • Bill Dozier Jan 14, 2009
    dmace you can buy that connector BUT you can find a old washer on the side of the road or at the dump or mayby at a local used dealer and rob the connector off one of them as long as it is a whirlpool or kenmore you can try appliancepartspro.com they sell some weird stuff on there that you can buy other wise good luck.....bill
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off an on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Washer only fills part way before agitation begins
The water level switch regulates your washer's fill volume. The switch is usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises the pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to shut off the water, and signals the timer to start the agitate cycle. If the switch is defective it may prematurely signal the water to shut off. If so, you will probably need to replace the switch. Hope this helped.
Jul 18, 2009 | Washing Machines
Machine will not agitate, but it allows the water to drain.
soundsas if you have possibly broken youor motor coupling( this machines "belt") easy repair, yo can see video as to how to replaceit by searching you tube for whirlpool motor coupling
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
