Question about Samsung Heating & Cooling
Model SH12ZAB/XSA not working, lights just flashing
Not turning on lights on unit inside just flashing
I have a red and green light flashing, fan work on inside but unit will not come on outside
There should be a diagram on cover that also show you what codes the flashing lights mean. I will need the model number of your outdoor unit to tell you what the lights mean.
Jun 06, 2017 | Heating & Cooling
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Why won't my unit come on?
Post the brand and model number and ill tell you what's wrong
May 09, 2014 | Haier HPR09XC7 Portable Air Conditioner
Hi I have a Samsung Tv. Model SP50L6HXX / XSA that wont turn on. there was a week buzzing noise for the last week or two, but tv will not start up now. The lamp light flashes on the front of tv. Can you...
I suspect the B+ voltage on the power supply can't regulate the voltage needed for the lamps to run entirely. The B+ voltage regulator looks like a small black box with a tapered top. This is dangerous to replace so be careful. Once you get a new one installed this will fix the issue you are having.
Hope this helps :)
Mar 07, 2011 | Samsung HLP5685W 56" Rear Projection...
The green auto light keeps flashing on the head unit of my a/c and i can not turn the unit on. It has power, it does work, every now and then the green auto led stops flashing and i can use the unit with...
Need model and make of unit? Take off the bottom door of your furnace and there will be a label on the inside or the outside of the door it will tell you what the flashed mean.
Nov 25, 2010 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Polaroid Digital Frame Model XSA-01140B freezes up
I was using an 8G flash drive and had over 6G saved to it. I decided that maybe the frame could not handle that many G's so I deleted everything but 2G and it WORKS!!!!! Maybe anything over 2G is too much for it to handle. Try it and let me know. I am interested if this solves everyones problems.
Dec 19, 2008 | Polaroid IDF-1030 (826219006783) Digital...
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
70 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
