Question about Breville Irons
Replaceing anti-calc cartridge breville steam generator iron lln194
Don't know procedure to change cartridge on iron
2 Suggested Answers
SOURCE: cant get anti calc cartridges for my steam generator
I had to order mine direct from Breville. If you go to their website and contact them with the model of the iron then they will give you details of price and postage.
Posted on Mar 08, 2009
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
How do I replace breville ironing catriged
Hello there,
From Breville website, there is NO insruction manual for the VIN 002 !!!!!
Go here for all of them
http://www.breville.co.uk/cat-search?cat=Irons&term=Manual
I don't know what you meant by 'cartridge' but Just looking at one randomly, it says.......
Anti-scale filter
Your iron is fitted with a permanent anti-scale filter. This filter is fixed and cannot be
removed for cleaning
Hope this helps
Sep 16, 2014 | Breville IN002 Iron
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Is my steam iron broke?
Get a new one. If it drew enough power to trip off your electricity then there is a problem that is not worth taking a chance on.
May 07, 2017 | Irons
My iron keeps going on to standby while using it. Any ideas as to why?
use the following ideas
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
May 22, 2013 | Irons
My iron is getting hot but giving no steam can anyone advise
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Anti/calc iron water pours out from evry where
see this steps and fix it. God bless you
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2012 | Frigidaire Fcl222/H 2200W Steam Spray Iron...
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Cant get anti calc cartridges for my steam generator
Aug 25, 2008 | Irons
Irons Logo
20 people viewed this question
Top Breville Irons Experts
Are you a Breville Iron Expert? Answer questions, earn points and help others
