Question about Lite On SOHC-5236K CD-RW+DVD Combo 52X32X52+16X Internal IDE White (Retail) Burner
Installation of new cd unit not working
Hi, first of all I am a bit of a dummy, I know very little. My cd rom drive was not working so I purchased a new one (no CD drivers were included - not that I know what they do!) I installed ok - or so I think.
I just done wire for wire.
Powered up and the cd rom drive is showing but with a yellow ! mark by it and the following statement come up when I right click on it:
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)
  • 1,179 Answers
Go to the cd drive manuafacturers website. Under support you should be able to lookup your drive model & download the software/drivers you need. Hope this helps.
Posted on Jan 10, 2009
How do I restore factory settings
The simplest way is to fully re-format the Hard Drive. Boot to any Windows installation CD or DVD, and when the option comes up, choose to install a new copy of Windows, and follow delete existing partitions and re-format HD options. For extra security, don't select "fast format". End this dummy installation after this formatting procedure. The most secure method for data deletion however is a bit more physical. Remove the hard drive and smash it with a hammer! You'll know the drive is well and truly trashed when you can here bits clanging around in the drive casing when you shake it.
Jun 14, 2014 | Compaq Presario R3000 Notebook
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I...
u have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
Oct 11, 2008 | HP Computers & Internet
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
May 18, 2011 | HP Compaq nc6220 Notebook
Cd rom drive problem
Hi, you can purchase cleaning CDs for your CDrom, if this does not work it probably meens your laser has gone and you will need to buy another one
Jul 04, 2010 | HP (176135-630) (176135630) Internal 48x...
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
Diskk wont spin
Hi, the dock motor that is designated for spin has burned out unfortunately. you will have to send this unit to Sony or, you can purchase another replacement ROM drive for your unit as well.
The ROM drive is only available for purchase threw Sony.
May 24, 2009 | Sony PlayStation 2 (PS2) Console
Error in installing wordtec webcam setup
Nov 20, 2008 | Intel Motherboard
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
My cd drive will not work. the cd goes in my computer makes some noise as if it is going round but nothing happens. it is like this for music cd's and cd rom's
Sounds like your drive motor gear is bad... Its time to replace the Unit. If its under warranty call your warranty provide, otherwise you will need to purchase a new drive and install it. Installation is VERY easy on a CD drive and can be done in only a few minutes in most cases.
However if you have reservations about doing it, I recommend contacting someone who is comfortable working on computers!
Sorry we couldn't fix it... sometimes they just break!
Jul 19, 2008 | Computers & Internet
Bootable cd / dvd
one possible way around is to copy the entire cd (make a new folder named "CD COPY" or similar) to your hard drive (assuming you have enough space...about 800 Mb), then run the install from setup.exe from the hard drive, then delete the copy (to make room) when you are done.
Mar 24, 2008 | Toshiba Portege M205-S810 Tablet PC
Lite On SOHC-5236K CD-RW+DVD Combo 52X32X52+16X Internal IDE White (Retail) Burner Logo
83 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
