Question about Kitchen Ranges
New Home Gas Stove 500 SI DL Top Grill Glass Door brocken. Need to purchase new door
SOURCE: how to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Posted on Jul 21, 2007
jsrock516
  • 5911 Answers
SOURCE: cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Posted on Feb 16, 2008
jsrock516
  • 5911 Answers
SOURCE: glass top range cookware
Here's the recommended cookware for glass top ranges:
Aluminum and Copper - have good heating characteristics, but may leave metal transfer marks on the glass.
Stainless - may take longer to heat and may not heat as evenly (some stainless has a copper liner to aid in heat transfer). More resistant to leaving metal transfer marks.
Baked Enamel - great heating characteristics, provides uniform heating and resists marks on glass surface.
Cast Iron - NOT recommended due to the weight of the metal. Can cause potential cracks or breakage.
Now, any reference to metal transfer marks are merely disclaimers from most manufacturers that the potential exists that the cookware could leave marks on the stove surface. Using a good cook-top cleaning product after the surface cools will aid in removing any of these marks. This does not mean this cookware should not be used.
All cookware used on glass cook-tops should have flat bottoms. There should be no ridges, grooves, or warping. This creates an uneven heat transfer between the pan and surface and can potentially cause the glass to break. Most manufacturers will not honor a warranty where it can be determined that the consumer used the wrong cookware.
Make sure you wipe up any spills on the stove surface that contains sugars or milk. These ingredients (if allowed to burn on the surface and are not cleaned up) will eventually cause damage to the glass surface by either removing the finish or leaving pits and cracks. Wipe up all spills AFTER the surface has been allowed to cool using a non-abrasive cleaning rag or sponge. The green scrubbing pads are considered non-abrasive and CAN be used. DO NOT use steel wool or SOS pads! A small straight blade razor can be used to remove stubborn items by gently scraping in one direction. I don't believe you can use any cleaning product that contains ammonia either.
All of this information can be found in the owners manual that came with the appliance. If you don't have a user/owner's manual, post back with your model number and I'll see if I can locate it for you. I hope this helps you.
Posted on Apr 17, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
SOURCE: Dirt and grease between glass in oven door
My husband cleaned this today!! Yahoo--I had over sprayed the glass cleaner and it ran in the vents.
If you pull out the drawer on the bottom, and look up you will find that the glass is being held in at the bottom by a "clamp" & 3 screws, one on each end and in the middle.
After you remove these, the glass front will come off, and you will see the inner door. There is another piece of glass that I cleaned, and now it looks 100 % better. Of course, the door comes apart easier than it goes back together, we had a little trouble lining up the screws. Don;t push the glass on too tight, the screw holes lined up better when there was a little space.
Posted on Feb 28, 2009
LG stove - glass cooktop broken - model LRE30451SW/SB/ST how do i remove and replace glass cooktop on LRE30451SW/SB/ST?
Open the oven door and you should see screws on the overhang where the door fits in,take those off and that should loosen the whole top of the stove,then you will see what to do next and what you have to remove to replace what you need,hope this helps some what.
Feb 19, 2014 | Kitchen Ranges
Do i need to buy the whole part...the grill door...or can a glass guy fix it
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 11, 2011 | Ovens
Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
heatman101
Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Hello i am cleaning my parkinson cowan cooker and i have took the gill door off and i cant put it back on, just wondering if you have instrouction please? thankyou
Position the glass between the metal plate and the white plastic handle contraption and secure with 4 screws. This is not very stable so hold the glass securely.
Pull the grill door forward 4inches, place the glass assembly with the lugs at the bottom in the corresponing holes on the grill door.
Move the top white handle and glass thingy towards the top of the grill door.
The secret to how this works is to make sure the sticky out things with holes in at either end of the metal plate/glass/plastic handle go under the lip of the grill door.
Place the remaining unattached to anything 2inch wide metal plate above the lip.
All the holes will line up. The screws screw into the affore mentioned sticky out things with holes in.
Thats it.
If you by any chance want a new website look at this.
Nov 06, 2010 | Parkinson Cowan SG553 Dual Fuel (Electric...
NEED PARKINSON COWAN - OVEN DOOR - GREEN -
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
Hi. The outer glass grill door has come away and smashed on the floor when going to open grill by the handle. Can't see that there were any screws in the bottom of this. Would they have been factory...
Sometimes the glass is bonded to the door (glued) which may be why you can't see any screws.
It seems as if you are going to need a new grill door complete.
Dec 30, 2009 | Electrolux EOG9330 Gas Double Oven
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
Securty door top glass broke
Your problem shows a stove, but I am guessing that you are talking about a door to your home. Use the Yellow Pages directory in your phone book (online FixYa does not provide local physical assistance) and look up GLASS companies in your local area. Call and get a quote for someone to come out and install a new glass pane in your door. If it is a security door, it will probably be TEMPERED glass. Hope this helps. If so, please rate me as helpful.
Jun 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
