Question about Health & Beauty
I need a user manual for a Bizerba CS 300 scales please.
I don't know how to set the tare in standalone mode and does it keep the tare when rebooted?
fitnessbalan
  • 59 Answers
SOURCE: Need an owners manual for taylor mod 5757 bathroom scales
here is the owner manual from taylor http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Posted on Apr 22, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
moman406
SOURCE: Lost the manual
http://www.wholesalepoint.com/documents/Homedics-SC-535.pdf
Posted on Sep 16, 2009
SOURCE: when I turn on the pocket digital scale there are
threw it out the f____n window
Posted on Jan 17, 2010
SOURCE: i keep getting e on scale dont know what i did
I think that those numbers are for the spacing of the feet? I'm not sure what that number is, but anyway you have to push select 3 times and it will save and then the scale will zero out. After that you can push one of the four buttons and program you height/age/gender. I think they really made this scale kind of user difficult.
Posted on Feb 05, 2011
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
My sway scale keeps telling me I'm 4.6 lbs. I know I'm not, how am i suppose to fix this? I just bought it off amazon and got it in the mail today.
Scale may have been shaken up during shipment. Check the owner's manual (if there is one) to see if there is a "Tare" feature or method that sets the scale to zero. This will effectively re-calibrate the scale. If no luck or no way to recalibrate, return the scale as defective.
Dec 02, 2013 | Health & Beauty
Need instruction manual. When weighing a container....how to set the weight so you do not have to subtract container weight
You have provided very little information and your question ended up in the vacuum cleaners category. I know your question is related to a scale so I will take a stab at a solution. If there is a "Tare" button, put your container on the scal and press the tare button, you should now see zero for the container and the scale will begin measuring the weight when you add something to the container.
Jun 27, 2011 | Vacuums
My digiweigh keeps reading out 2 i changed the batteries but it still is reading out 2 what does out 2 mean
it needs to be cal turn on hit tare hold down until number show mine went crazy -628.2 anyways now hit mode an hold it down if it dont work an keeps turning of be quick turn on hit tare an hold down keep doing it till u get it took me about 3 times till i got it
Dec 04, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have a CE100 Bizerba scale-I keep getting the operator invalid code & it will not let me change anything or print from it.
As far as I can tell, if you go to their website, and register with the site or register your product, you can get all that information online. Their website:
http://www.bizerbausa.com/
May 10, 2009 | Computers & Internet
Bizerba pro 9000 printer scale manual
bizerba GLM I70. On the only one product with weight is printed 0,416g and sometimes ,416g
Mar 28, 2009 | Kitchen Appliances - Others
Health & Beauty Logo
799 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
