Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Replacing pull cord on troy built mower model # 8654r 4hp
How to replace the pull cord . thanks
  • 50 Answers
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Posted on Feb 06, 2009
How do I replace the pull cord on the Troy Built Mower model # 12AI867Q011 serial # 1E098KC0419
You have two options. look up your models starter assy. at a dealer like www.arcolawn.com and replace it as a whole or purchase the rope remove the starter, charge the spring by twisting it all the way tight, back it off one turn and install the new rope. Tie your knots and reinstall the starter.
Thank you
Joe
Oct 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have changed the air filter and bought a new spark plug but my troy built with Honda 160 cc engine will not start.
there is a possibility the c oil is bad, pull the plug and with wire attached pull cord to see if any spark
Aug 07, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I need to replace the pull cord on a 4hp, yard machine, 21",mower
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 20, 2009 | Mtd 22" Yard Machine Push Mower
Cord is pulled out what do i do?
take off the part the cord goes into and put the cord back into it its spring loaded probly kinda tricky its diffrent on each model but there should be a place to tie the the cord into and put it back together cord probly dry rotted if the cord is in really bad shape you can buy a complete replacement
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troybuilt selfpropelled mower Model # 8654R
You can go to Troy Bilt website Customer Solution Center. There you can view/download and print owners manuals. I found the detailed solution to my question there. Best part...it's FREE!
Apr 12, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Jan 10, 2009 | Garden
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
899 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
