Question about Tomtom ONE GPS Receiver
How and where do I replace a fuse on A tom tom one car power cord
Unit turns on then right off--suspect power cord .Checked car fuses--All OK-outlets working
  • 1 more comment
  • peterfrain19 Jan 11, 2009
    thanks----as it turns out -replaced fuse--still shorted out. it seems that the cord fried on the inside--got a universal cord at radio shack
  • peterfrain19 Jan 12, 2009
    Thanks---Jusr ngot a universal at ridio shack
  • Anonymous Mar 20, 2009
    can not find same size fuse??!!
    Champion:
  • 240 Answers
Ther is a small batery looks like large watch battery or computer battery inside unit.
sumtimes thay are soldiderd in place.
you should change it with new one.
this will fix your problem.
Posted on Jan 11, 2009
  • Daniel Conklin
    Daniel Conklin Jan 12, 2009
    voltage regulator section of pcb is then sorted replace v reg ic and serounging componets should work fine.
    I wold also look for original power cord.
    soundslike to much voltage hit the unit.
    regards,
    daniel.
Have had this JWIN model JK-777 turntable/am-fm/cassette/cd player unit. It won't power on now. Checked the outlet, no problems there. Does this unit have a fuse?
1. It's more likely the problem is a broken power cord or dirty power switch. If you've been in the habit of yanking the cord to unplug the unit instead of pulling directly on the plug, or somebody tripped over the cord, the power cord is probably broken right at the plug.
2. Changing a blown fuse without finding and repairing the fault that blew the fuse will only give you another blown fuse. It's not like the old farmhouse with too many things plugged in on the same fuse... A blown fuse in audio equipment is usually the result of a shorted speaker driver transistor. The transistors come in pairs; if one is bad the other has been overloaded and should be replaced also. That's a job for an electronic technician.
Nov 22, 2017 | Jwin Audio Players & Recorders
The microwave will not turn on. No power. Checked fuse box and power outlet...not the problem. Unit just wont turn on? Is there a reset button or another option.?
Remove the cover and locate the internal fuse you will find near the power cord entry. Replace with the same.
Sep 04, 2011 | Vacuums
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
No power I checked the power outlet and I have 115V there Is there a fuse some ware??
If everything is ok, the fuse of microwave oven is located inside the unit, if you have a screwdriver, unplug the power cord and open it, you'll find the fuse
Aug 09, 2009 | Frigidaire PLMV169DC Microwave Oven
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
No power
You blew a fuse in the car plug. Unscrew the top of the car charger and you will find a fuse inside. You can get replacement fuses at a hardware store or Radioshack.
Feb 02, 2009 | Sirius Starmate ST2 Satellite Radio...
Tomtom ONE GPS Receiver Logo
704 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
