Question about LG WM-2277HW Front Load Washer
Getting no display and door is locked
LG Front load WC2077, when I came home from work the washer looks like it spun but the door is locked and there is no display. I checked the breaker, all ok. What could be wrong? I can't get it to respond, I held the power button down and the pause button, but no life. Help!
Thanks
  • chipperzown Jan 11, 2009
    I have unplugged it for over 5 minutes and plugged it back in, the door unlocked, but still seems like no power to display. I tried it with an extension cord on another circuit, same thing. What happened?
    Sniper:
  • 88 Answers
Most likely cause; dead main board.
A technician should check the following to confirm:
1. Check that the AC outlet has 110V
2. Check that 110V is going from the power cord to the AC filter.
3. Check that 110V is exiting the AC filter to the main board.
If all this checks out then it is definitely a bad main board that will need replaced. Hope this helps, please rate my solution.
Posted on Jan 11, 2009
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The front door is locked and cannot be open.
Look for a thin clear looking line in the soap dispenser. Pull the soap dishes out and look towards the front closest to the door. It looks like fishing line but it is the door lock release. Pull it to get your door open and clothes out. Most common part needed in this situation is a new doorlock assembly (part #22003593). I hope this helped.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Broken washing machine
we also have now gotten the same message and same poor help the company is aware of this problem but sadly, the almost $500 replacement to fix the problem is the same original parts that go wrong in the machine so they haven't upgraded the replacement parts which means you pay to get the new part--WAIT for it to arrive because NO ONE stocks LG parts, and then the new part is not any better than the original. We are selling ours and getting a Kenmore.
Nov 27, 2007 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
94 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
