I changed the ribbon and it doesnt move - Office Equipment & Supplies
  • 3,594 Answers
Make? Model?
Posted on Nov 30, 2012
Warning ribbon in
the ribbon sensor it activated, change settings from lcd panel to Direct thernal, and check if settings from driver are correct, Thermal Transfere if using ribbon, Direct thermal if doesn't use ribbon, ru calibration if needed, or if doesnt work, you can do the manual calibration and/or reser to factory default. Hope it helps. Paulo.
May 16, 2014 | Zebra S4M Thermal Label Printer
I have brand new Zebra 220Xi4 (203 dpi) and i was printing labels very good, but suddenly the printer keep saying riibon out but there is a ribbon and a media A4 format, i try to move the sensors inside...
read your instructions to calibrate ribbon and label sensors. if you dont have it you can download it from zebra. if that doesnt work dont mess with it and contact zebra for more help. i dont think you can move the ribbon sensor at all. just make sure no label debris is on it
Jan 21, 2018 | Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
Change a swintec 1186 typewriter ribbon
Move the red lever to the front of the ribbon, remove it, drop the ribbon in place, be sure it goes thru the feed roller on the left, move the lever back, done.
DickyO
Oct 26, 2009 | Swintec Office Equipment & Supplies
Lots of Vertical lines on screen
most likely bad screen, bad cable, or loose connection at the video card. Some laptops wear the ribbon cable that feeds the video signal to the screen around the hinge point and it will wear through. If moving the lid up and down doesnt change the image, it more than likely is in the screen itself. The chips along the perimeter of the screen are breaking down.
Sep 28, 2009 | Toshiba Qosimo G35-AV660 Notebook
I have changed the flex ribbon on my n80, but now when i turn it on the buttons light up but the screen is blank
dear,
you changed due to this kind of problem?? is it...
if yes, then properly plug the strip/ribbon properly and if it is properly connected then you have to check the ribbon itself because sometimes it doesnt work....as i experienced.
goodluck..
Aug 15, 2009 | Nokia N80 Cellular Phone
Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Apr 04, 2008 | Intermec EasyCoder 3400 Thermal Label...
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
Brother AX-450 Electronic typewriter
Hellooo.
2 thing come to mind you may check.
First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty.
2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon.
Lastly the ribbon drive may be broken or out of adjustment. a minor repair.
Hope this helps...
Squipps
Jan 08, 2008 | Brother EM-430 Typewriter
New ctg. change problems
In the printing preferences there is an auto detect ribbon button . you should select it.
Your ribbon will be updated. Also if printer asks you if the ribbon is correct select yes. The printer will then print on whatever ribbon you have intalled. This doesnt work with test prints
Dec 26, 2007 | Fargo Persona C30 Thermal Card Printer
13 people viewed this question
jasbo
jasbo
