Question about Philips SPC611NC Webcam
I am having a problem with the phillips spc611nc web cam it keeps failing the sound test in skpe does it not have a mic?
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
On to my second web cam, tried logitech and now microsoft life cam 3.0, no problem with video but can not get any audio!!
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Dec 10, 2010 | Microsoft LifeCam VX-3000 Web Camera
Well I have a msi laptop and the built in web isnt working and I checked if it was on and it says it is. But when I go to skpe or msn nothing happens and the little light beside it doesnt go on? I need...
You will have to set up or configure your webcam software to work with any chat program before you can broadcast.with it.
If it has a built in mic with the webcam -Make it your default mic.
TEST SPEAKERS
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jun 13, 2010 | Computers & Internet
I have procured a iball C8.0 web cam. It is working alright,the receiving end though are able to see me on their monitor they are unable to listen me. i fail to understand how to enable Mic. Where the...
On the back of your computer you should have a couple of round audio sockets or jacks
One is black for a headset and the red one is for a mic
After plugging in - make your webcam mic the default mic.
TEST SPEAKERS
Restart computer
Configure your webcam to the chat program
May 29, 2010 | Microsoft LifeCam VX-3000 Web Camera
People can't hear me on the web cam when talking to them but i can hear them
Make sure that you plug in the Mic jack properly and it's working, you can test it using built-in sound recorder if you don't have any audio editor software. Try with different mic and see which one is the problem. Also your mic socket (onboard or ad-ons card) maybe the problem, so troubleshoot thoroughly and slowly. Good luck..
May 12, 2010 | Computers & Internet
I try to record a video with my web cam and it has no audio
Hi, first of all you need to make sure you have the microphone configured properly. If using the cams built in mic you need to make sure it works . If using XP Open the control panel and click the sounds and audio deviecs, click the voice tab, there you can select which Mic to use: the USB cam mic or another mic , then click test hardware. If you should see a mic playback test. if the level is there then the mic is working. next see if there is a mic level test/adjustment within the camera software, if using skype you also need to set it up and turn up the Mic level there too. you may need to add a mic, some USB cam built in mic aren't that good. you can buy a cheap mic and plug it into the pink jack.
hope this helps, please leave a 5 thumbs up if this helped
Eric
Aug 17, 2009 | Facebook Social Network
I have lost the installation disc. how can i get my web cam working
Download software and driver here
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&cat=PC_CAMERAS_CA&sct=WEBCAMS_SU&session=20090729191625_86.0.182.131&grp=PC_PRODUCTS_GR&ctn=SPC611NC/37&mid=Link_Software&hlt=Link_Software
Jul 29, 2009 | Philips SPC611NC Webcam
My problem is with a Logitech WebCam with a built-in Microphone. The Mic does NOT work . It works on another LapTop ( with the same Vista ) but not in here ( PC with Vista ) I tried most of the the trouble...
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Apr 07, 2009 | Logitech Webcam
Phillips spc11nc
Yes, but you have to select it in the Audio Settings in Skype. Here is info to help.
A. Skype Setup:
B. Yahoo Setup:
Jan 10, 2009 | Philips SPC611NC Webcam
What's skpe credit
you only need skype credit if you wish to use it to make telephone calls. otherwise you will be ok
Dec 19, 2008 | Computers & Internet
Web camara logitech
it usually doesnt disable the mic on webcam and go out and buy your self a logitech usb mic the quality is better and it works the web cams dont work ever and always conflicting with other irq'd software
May 28, 2008 | Logitech Webcam
Philips SPC611NC Webcam Logo
44 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
