I want to buy forsa graphics card can it run assassin creed 3 my pc configuration 2.8,4,gb ram
SOURCE: i have a nvidia geforce 9400 Gt graphics card how can i overclock
Read this...
You're not going to get a lot out of that card,
it's pretty stripped down being a 9400. Anyways, download Rivatuner
then after it detects your video card it will update your registry
which will allow it to manipulate your video card.
You then use it to increase your Memory and Core clocks, and also the
shader clock in VERY small steps. Increase it by perhaps 20MHz then try
playing the most visually demanding game that you own and play it for
like 5 to 10 minutes and watch for anything out of the ordinary. When
you've pushed your card too high there are obvious signs, like random
pixels flashing across the screen, textures showing up wrong (colours
where they shouldn't be), or your game can simply lag or crash.
Also download Speedfan and monitor your GPU temperature closely. See
what it idles at normally, then use Rivatuner to increase your fan
speed to somewheres around 75% and make sure that the temperatures
don't pass 70C.
Overclocking voids warranties and you can damage your graphics card if
you push it too hard. You have to be careful and watch for signs that
it's being pushed too hard. Also, you have to make sure that you set
your clock speeds back to normal when you don't need the extra power.
It's easier on your card then running it at 120% or something
permanently.
Rivertuner: http://www.guru3d.com/index.php?page=riv…
Speedfan: http://www.almico.com/speedfan.php
Hope it helps...Good luck
SOURCE: I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Can i run forsa nvidia gt610 2gb ddr3 graphic card in 32bit system
