How to program a AM7 AUTOMATE REMOTE 474A - Televison & Video
    Top Expert:
  • 12,223 Answers
Please read your owner manual , if you do not have please download it
for free. go to
www.fitness.manualsonline.com or www manualslib.com
God bless you
Posted on Nov 29, 2012
Daily starts not programmed
you need to take it to the remote start system installer - they may be able to change the coding of the signal to avoid this proplem or they may (worst case scenario) have to disable the remote starting part of the system until the cause can be identified and corrected.
Apr 05, 2014 | 477A Automate 2Way Replacement Remote ...
Car starts without using remote
Timed start. The timed start mode is activated by pressing the lock and unlock button simutaneously. The timed start mode is canceled by starting the car with the key or pressing the brake pedal while the remote starter is activated.
Jul 29, 2012 | AM7 Vehicle Security System with Remote...
I have a model 2 automate keyless entry system, will a ford key fob program to it, and how do i program it??
no idea with these boy racer add ons i encounter i just cut them out completely because once they play up its impossible to repair then ,especially these viper remote start junk i encounter on imported vehicles from america ,these junk things wouldnt stop me from lifting a motor ,just use a breakdown truck and no one pays any attention .
Apr 28, 2012 | 1996 Ford Taurus
How to program a am 7 automate remote 474a
I purchased a automate 474K remote from Autozone and the instructions were to find a single button under the dash and set the new remote to the old settings. There is no single button, as far as I can see. But there is a large 2 x 3" wiring block where the antenae wire plugs into. There are many other wires also plugged into this "Automate" block. But no button.
What do I do ?
Feb 24, 2012 | Televison & Video
My remote has zzzz above the car picture and when i set or unlock the alarm there is no sound coming from the remote or my jeep how can i fix this
Your alarm is in valet. Open any door, press lock, unlock, lock on the remote. Close the door, test the system. You should hear the chirps now.
Apr 21, 2011 | 477A Automate 2Way Replacement Remote ...
We have a 2005 GMC Envoy that has had an Automate remote starter installed prior to our purchase of the vehicle used. The remote is nearly worn out. Our GM remotes will only work to lock and unlock the...
Without knowing how old the battery(s) in the remote are, I would suggest that to be the first thing to replace. It is relatively easy and inexpensive to do - and could solve the problem.
You can attempt to pry the remote apart to access the battery(s) after removing the remote from the keyring, or bring it to a Batteries Plus store (or a hardware store) where an employee can replace it for you.
Beyond that, you'll probably have to return to the place of installation of the starter to resolve the issue. A phone call to the installer may be able to solve the problem over the phone instead of having to go there.
Sep 14, 2010 | GPS
Key remote for 2003 lin. navigator how do i reset
Hello
I hope I can help
You could have a flat battrey or it just needs reprogramming
NOTE
If the truck has memory esats seats YOU must program remote number 1 this will be maked on the back.
  • Switch ignition from off to on 8 times within 10 seconds (fast)
  • The doors should lock & unlock
  • Then press any button on the first remote
  • Then do the same for the rest of the remotes
NOTE
If the door locks do not operate: wait several seconds & then press the button again
  • Switch ignition OFF:
  • Doors should lock & unlock
NOTE
A maximum of 4 remotes can be programmed
Regards Paul
www.limotec.co.uk
Jan 13, 2009 | 2003 Lincoln Navigator
Check Engine Alert
No not that I could find, before you remove the whole this just pull both fuses on the main harness red wire there should be 2 total, also check to see that the white ignition wire is hooked up to the remote start unit as this is a very important wire that needs to be hooked up because it is tyed in with your transmission system
Dec 28, 2008 | DEI Valet Keyless Entry System
Televison & Video Logo
599 people viewed this question
Top Televison & Video Experts
