Question about Propellerhead Reason 5
Registration code for reason 5 - Propellerhead Reason 5
Casio WK-3500 How to save keyboards/tones
Yes there's a way. Use Registration Memory (I shorten it to: RM) ..
RM have 8 banks and 4 bank numbers. For changing banks, press BANK several times.
Example :
  • choose tone (eg:500)
  • press BANK where you want to store. (eg:1)
  • while holding down STORE button,press registration number where you want to store (eg:3) Release store button. Finish.
Next :
  • choose tone (eg:038)
  • while holding down STORE button,press registration number where you want to store (eg:4) Release store button. Finish.
Anytime you press RM bank 1 number 3 (one key), the sound is 500
Anytime you press RM bank 1 number 4 (one key), the sound is 038.
Notes:
  • RM not only can save tone, but can store style,overall setting live performance,etc.
  • RM functions are disabled while you are using the SMF player, song memory or demo.
  • RM are also disabled while you are using the floppy disk drive.
Jul 10, 2015 | Music
Reason 5 is not working on my laptop
Here is a link to Reason updates - note the 5.0.1 update - try that - you may have to register first.
http://www.propellerheads.se/download/index.cfm?fuseaction=get_article&article=reason_updates
Apr 09, 2014 | Propellerhead Reason 5
I need an activation code for pro tools 8?
When ProTools is installed on a computer it needs to be authorized to work. This has to be done via a dongle, a socalled iLok . The authorization is done by www.ilok.com. You need a dongle with the authorized registration of ProTools on your computer to make ProTools work.
regards
Mar 09, 2014 | Digidesign MBox2 Mini with Pro Tools 8 LE
After installing reason 5 there is a prompt for what disc?
What exactly does it ask for?Did you try putting it back in?
Feb 20, 2013 | Propellerhead Reason 5
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
I can only hear the first instrument i use. After that all other instruments are silent
yea im having the same issue.reason worked fine on my other comp.but as soon as i installed it on my laptop, i got this problem,it only plays the first instrument i load on my audio rack.if you toggle to the rear of the audio rack (press tab to view) the wires are not connected correctly.so i added a line mixer 6:2 and re routed the wires myself..and got it all working.
Jun 08, 2011 | Propellerhead Reason 5
I just got the reason 5 upgrade and I can not open it. It says ar does not support program. I have a G5 tower dual processer OS is 10.5.8. When I try to open the upgrade I get a error message say this....
Try getting the newest version of your OS. there are quite a few programs that are compatible with a certain operating system, but you need the latest edition to get them to run.
Hope that helps!
Feb 08, 2011 | Propellerhead Reason 5
Hello. I am having a problem with Reason 5. The sound will not work- although I am getting a signal from the mixer, and it was working just fine a minute ago, there is no sound coming out of the...
I have the same problem, no word from Reason yet.
but what i keep doing is re-enter the program.
what i THINK the reason is, is that if you have soo many number of instrument programs hooked up to the mixer and what not, it blows reason 5's mynd!....
it has to be, because 3-4 yea your good, but 7 8 9 10, thats when i start getting problems! even fruity loops did a little better then this....(sad face). if i kno how to fix this foreal FOREAL, den ill post back..
Dre'
S.C
Jan 13, 2011 | Propellerhead Reason 5
Propellerhead Reason 5 Logo
438 people viewed this question
Top Propellerhead Music Experts
Vito Vacirca Jr.
Are you a Propellerhead Music Expert? Answer questions, earn points and help others
